Tire help please
Old Jun 10, 2010 | 04:03 PM
Richor's Avatar
Richor
CF Lifetime Member
Default Tire help please
Im looking for tires to put on my stock c6 base z51
I found a good set of 295 rears. I know they will fit regarding width but the only profile alot of manufactures make is 295/30/19 vs 295/35/19
The car stock comes with 285/35/19s on the rear
will I have an issue with the 30 profile vs the 35?
Thanks guys
Old Jun 10, 2010 | 04:17 PM
Richor's Avatar
Richor
CF Lifetime Member
I want to still keep the active handling working. From what I just read you need to reduce the height equally with the front and rear
Stock is 245/40/18 and rear 285/35/19
What I want to put is 255/35/18 and 295/30/19
That should work right?
Old Jun 10, 2010 | 05:40 PM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
I believe it will, you would be reducing the front OD by approx .75 and the rear a little less than that but pretty close...what tires are you looking at?
Old Jun 10, 2010 | 07:05 PM
Richor's Avatar
Richor
CF Lifetime Member
the yokohama advan neova Ad08's.
180 treadware rating. should be much better than my 300 treadrating bfgs on the track. Thanks for the response ~
Old Oct 8, 2010 | 11:39 PM
V8Juice's Avatar
V8Juice
6th Gear
Did you ever get these tires? I'm looking to do the same thing on my 08 Z51 so I can stay stock at NCCC events; Re 11 and the AD 08 are supposed to be the best for this application, but only the AD's are available in the larger size. Thanks, Peter (I'm new here)
To Tire help please
