C6 locks it's self---Mystery ??
Old Jun 18, 2010 | 12:34 PM
terry s's Avatar
terry s
Default C6 locks it's self---Mystery ??
A friend of mine has had their 2005 C6 lock its self with the keys inside on 2 occasions in the last few weeks. Both times were at the car wash. The first time they had the spare key & fob with them and last night both sets of keys were in the car and the car was running.
It took 2 hours for a locksmith to get there!!
They thought maybe the wash guy had hit the lock button & closed the door. But I tried it today. I put the key & fob in the car. It beeped when I pressed the lock button, I shut the door and it would not lock just as I thought it should do.
Does anyone have any ideas what is going on?
Old Jun 18, 2010 | 01:24 PM
BigMay60's Avatar
BigMay60
I have a 2006 and mine has done this before. If at any time, the car does not see the FOB (with passive locking on), it will lock the car. It thinks the keys are out of the car.
My battery is good, but sometimes my car will not see the FOB at certain positions in the center console or passenger seat.
In order to assure this will never happen again -- TURN OFF PASSIVE LOCKING. (Look it up in the book -- this is in the set up)
Old Jun 18, 2010 | 01:30 PM
TXC6Z51's Avatar
TXC6Z51
If you have passive locking activated, don't leave the keys in the car period.
<--Learned this the hard way and I only had one set of keys at the time
Old Jun 18, 2010 | 02:39 PM
BEZ06's Avatar
BEZ06
A couple days ago when we recently talked about this same topic, I was rather ruthless with recommendations to do a search to find a few of the bazillion threads about locking your fob in the car.
So....I'll just refer you over there for a whole bunch of info:
http://forums.corvetteforum.com/c6-c...the-trunk.html
Please advise your friend with the C6 to get on the forum. That's the beauty of it - you can learn all kinds of stuff from the experiences of others.
In addition to never closing the door or hatch/trunk with the fob inside, my best advice is: 1-keep the key separate from the fob, so if they do lock the fob inside all they need to do is use the key to open the car; 2-tell your friend that all they needed to do was call OnStar and have them pop a door open.
Also - tell them to check the key to make sure the cable from the key lock cylinder above the license plate is properly connected in the lever inside the hatch/trunk release.
Yes - you CAN lock the fob inside the car!!!
Bob
Old Jun 18, 2010 | 04:15 PM
terry s's Avatar
terry s
Thanks all for the fast replies and good info. I did search although apparently not very well. I did not mean to cause any aggrivation by posting.
They did call Onstar knowing they were not subscribed and as expected they would not unlock the car.
I have my 08 set to lock as I walk away from the car. However when I get home I get out of the car and close the car door so I can raise the garage door. The car has never honked or locked. I assumed that this was because the car was running and it knew not to lock the fob in the car with the engine running.
I have turned the car off in the garage, got out & shut the door with the fob inside and it honked a few times like it is supposed to. The only difference for me between honking & not honking was shutting the car off. This is why I was surprised that my friends car locked its self with the engine running.
Old Jun 18, 2010 | 04:17 PM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
Bob
Not every Vette has On Star.
OnStar will not work in certain locations either.
Never under any circumstances leave fob in a car unless the windows are down.
Always keep fob on your person, way too many posts here because this is not done.
Set your alarm to active, that way you control when and where the car will lock. It’s no big deal to push the lock button when you get out of the car and THEN PUT THE FOB IN YOUR POCKET.
The car will unlock when you push the door button WITH THE FOB IN YOUR POCKET! The car will then start with the FOB IN YOUR POCKET!
I often wonder what people did before this fob start system came out.
Old Jun 18, 2010 | 04:58 PM
BEZ06's Avatar
BEZ06
OnStar will not work in certain locations either.....
That's true - my 2006 Z06 doesn't have OnStar.
My fob is in a Harley Zippo lighter pouch on my belt - no way to lock it in the car unless I take it off my belt and throw it in and close the doors/hatch.
I know for owners that go to the gym, or to play tennis or golf, they may put the fob in their gym/tennis/golf bag and put it in the car and close the hatch/trunk. Unless you have a key in your pocket or wallet or hidden in a magnetic container somewhere under the car, you can be SOL without OnStar.
Bob
Old Jun 18, 2010 | 06:59 PM
haljensen's Avatar
haljensen
As BEZ06 has stated so many times;
It's simple, read the Owners Manual on how to DISABLE the automatic locking. You'll never lock the fob in the car since the fob has to be in your hand to lock the car.
Old Jul 14, 2010 | 09:21 PM
fnsblum's Avatar
fnsblum
If everyone used the search and actually found what they were looking for there would absolutely be no one on here talking. Later! Frank
To C6 locks it's self---Mystery ??
