Rotors
Old Jun 18, 2010 | 10:56 PM
Cherokee Nation's Avatar
Cherokee Nation
Default Rotors
I have a 08-Z51 with 29000,I'm going to change over to ceramic pads.The car has never been on th tract,just normal driving.Question:Should i have the rotors turned.
Old Jun 19, 2010 | 12:40 AM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Unless they are grooved/damaged, no. Don't forget to bed the pads.
San
Old Jun 19, 2010 | 08:43 AM
Walt White Coupe's Avatar
Walt White Coupe
San
If they are damaged or grooved don't waste your money or time on turning them, get new ones.
Old Jun 19, 2010 | 04:49 PM
Chris_B's Avatar
Chris_B
If you are changing pad compounds and the rotors have sufficient thickness and no grooving, you will not need to turn them necessarily. HOWEVER, you should definitely scrub the old pad transfer layer off with either Scotch-Brite (and elbow grease) or a Flex-Hone (much easier!). Some pads compounds are incompatible with others, and mixing two transfer layers can lead to trouble.
Do not use any sort of sandpaper as it is nearly impossible to keep the rotor surface flat by hand. Sandpaper will remove iron where the other two methods above will not.
Chris
Old Jun 19, 2010 | 09:22 PM
Cherokee Nation
Thanks Guys,..,
To Rotors
