need exp advise
Old Jun 21, 2010 | 11:57 AM
NikC6's Avatar
NikC6
Default need exp advise
hi everyone,
I have a problem in my 2006 covette.I was driving back home(thur) a few days back and got a msg check coolant level .To avoid any problems I put in preston dex cool along with distilled water in the surge tank till the full cold level. I drove for like another 35 miles on fri (the coolant level was full in the morning) and noticed again the coolant was low when checked at night .I did not drive the car after seeing the low coolant.This morning (mon) I again added more coolant with water and then when I tried to start the car it is not powering up.Like the engine tries to power and then goes dead similar to if a battery is low..Any ideas on why this might be happening.Is this cause for a major problem?
Any advise would be helpful.
Old Jun 22, 2010 | 11:03 AM
Larry/car's Avatar
Larry/car
I hate to say this but that coolant is going somewhere. If it isn't on the floor it is in the engine. You could have liquid lock. Pull the spark plugs and check for coolant.
Old Jun 22, 2010 | 02:54 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Blown head gasket will cause internal coolant leakage. If you don't see coolant on the floor, it's going into the engine.
Old Jun 22, 2010 | 03:17 PM
NikC6's Avatar
NikC6
thanks guys.I noticed yesterday that there was liquid under the passenger side..I guess that is probably the coolant.Will keep you guys updated on what is causing this..It looks like it could be the gasket or the water pump.
Old Jun 23, 2010 | 12:19 AM
NikC6's Avatar
NikC6
The issue was the water pump...I didn't expect the water pump to give out in just 40k miles..Guess I was wrong..
Old Jun 23, 2010 | 07:43 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
You never know about water pumps, but I too would expect 40K miles to be premature. I'll keep an eye on my 2006 with 30K on it. Good luck on your repair.
Old Jun 24, 2010 | 02:46 AM
NikC6's Avatar
NikC6
The guy who fixed it told me he has already seen 12 c6's with this problem and this happens all the time.This is an issue only with c6.I hope sub you wont have any problems in your 2006 ..
Old Jun 24, 2010 | 11:01 PM
Gering's Avatar
Gering
Tolero Apto Victum
Just hit 92,000 miles on my 07 C6 so I will keep an eye on my.
Old Jun 25, 2010 | 12:26 AM
NikC6's Avatar
NikC6
Sure Gering.I hope you wont have any problems either.This seems to be more of an issue with 2006 ones..I ended up getting a tune up done as well since the spark plugs had to be replaced..The pumps itself is not expensive.Luckily for me the hoses and the gasket were just fine..So if you see coolant leak it probably is the pump as the gaskets dont break that easy and it has to be hit really hard..
Old Jun 25, 2010 | 12:31 AM
Gering's Avatar
Gering
Tolero Apto Victum
Thanks for the info. I hope you are back on the road soon.
Old Jun 30, 2010 | 02:08 PM
NikC6's Avatar
NikC6
Sorry for the late response as I didnt log in for a while..
vette is back in action....No problems at all.....
Gering-Have you purchased any extended warranty on your 07 c6 since it already has hit 92k miles?I plan to keep mine for a long time as well!
To need exp advise
