Having such a healthy aftermarket is both a blessing and a curse. I'd like my first mod to be an aftermarket intake. However there are sooooo many available I don't know where to start. Is there a definitive "best" and if so, why?
Do these intake really add 30hp (either wheel or crank hp)?! like some advertise?! Thanks in advance!
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
30 HP??? I wouldn't bet on it.......maybe 15 HP. There are 3 or 4 good CAI's...that "C" is for "cold" air. That's the most important thing you can buy.
Larry
P.S. I assume your talking about the plastic thingy with a filter on the end of it.
When I bought my '07 new my Vette Pro shop before he did anything else put on a Fast Intake which he made better by smoothing or boring out the sharp corners on the inside of the intake.I call it my mini supercharger. Of course then came the Corsa Sports, Heads, Headers, Crossovers, Cam, all my gears splined and put back in a Z06 housing. All this work caused my paddle shifter to become useless as it shifts through all six gears in a nano second. What I wanted was a Z06 with an automatic...What I have is a genuine "sleeper".
there are several threads documenting gains and lack of gains... do some research , even on ls1tech there is some actual good threads documenting lack of big gains.
Stock ported intakes seem to do well depending on who ports them but most aftermarket intakes (FAST) have never lived up the the hype of their advertised numbers. The best intake wont fit under the hood but really you should be looking at application and why you think you need a bigger intake? What year and model? cam ? heads?
When you spend the money that these intakes cost and the performance increase (10 hp??), may as well stay with the stock system. The ability to say; I accomplished a mod on my intake system, is probably the return for the investment.
Kinda like the person that spends money they don't have to impress people they don't know....
Modifying the intake system with only a filter and intake pipe change will never be a huge performance improvement by itself. Without changing the engine computer fuel/air scheduling, the additional airflow could actually reduce power, and affect engine response to throttle changes. The engines are adjusted by the manufacturer to provide the best performance, and meet emissions requirements. Care must be taken when changes are made to the stock system, emissions are the first to suffer and you will deal with this every time emission checks are due.
Why? Because it actually brings in cool air from outside.
Seth
agreed.
What you engine needs is cold/fresh air from outside of the engine bay. Vararam actually does this PLUS its in front of the car which means "ram air" forced into the intake.
Doesn't the stock intake take air from the front of the radiator? If so, isn't it a "cold air intake"? The extra benefit of the "ram" air of the Vararam looks interesting.
No, it uses hot air from the engine compartment. Cold air intakes like Vararam and Honker require cutting the shroud.
Something you might want to consider is the Vette-Air. I installed one about a month ago and kept the stock filter, and I like it.
Another good thing. It must have changed my F/A ratio a little. Where I use to cruise at 75 and get 28 MPG....this weekend I made the first long run since I have had it.... I was getting 32 MPG, and it was a 100 degrees outside. NO tune....YET.
Don't think I put out great numbers just because I bought it. If I had lost anything you would have heard about it, even if I was smart enough to buy it.
Larry
Seems there has been some discussion here about cold air intakes (air filters) and intake manifolds (FAST). I think the OP wants info on the cold air filter systems.
