vette air surging
Old Jul 1, 2010 | 12:26 PM
child_of_fire's Avatar
child_of_fire
Default vette air surging
anyone know if the surging issue was found to be standard on the '09 LS3 with vette air and a stock/attack blue set up? looking to add the vette air on my 09 but want to rule out/find out if the surging issue has been taken care of. thank for your input.
Old Jul 1, 2010 | 03:24 PM
mittens's Avatar
mittens
black wing made my 06 ls2 car surge at ppart throttle until warm. tuning fixed.
Old Jul 1, 2010 | 03:58 PM
///DarkSide\\\'s Avatar
///DarkSide\\\
St. Jude Donor '12 thru '26
08 LS3 here w/ vette-air & halltech - I have no surging
Old Jul 1, 2010 | 04:55 PM
Elless2's Avatar
Elless2
I'm running a Vette-Aire with an Airraid on my LS2 with no issues.
Old Jul 1, 2010 | 05:09 PM
lebvette's Avatar
lebvette
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
The Attack Blue will surge sometimes. It seems to need a baffle to help the problem. Most of the after market filters have a closed end facing the Vette-Air(aka baffle),and usually don't have problems with surging. I kept my orginal filter, and had no problems.
Larry
Old Jul 2, 2010 | 11:32 PM
ray jr's Avatar
ray jr
what is a vette air ?
Old Jul 3, 2010 | 09:30 AM
lebvette's Avatar
lebvette
It's an air scoop that sets in behind your grill and deverts air into your intake. It's a well built item, a simple concept, and will not lighten your billfold near as much as some items. Do a 'search' and you will get more info, and actual pictures on it's mounting. 'Myhardtop' on the forum sells them. I have one, and really like it.
Larry
Old Jul 3, 2010 | 09:54 AM
tomiboy's Avatar
tomiboy
Larry
The vette air blow straight into the stock opening and probably causes turbulance
Airaid or Halltech are not open right in front of the vette air scoop
Old Jul 3, 2010 | 10:48 PM
Myhardtop's Avatar
0Myhardtop
Former Vendor
Ray,
The vette-air scoop is this:
Thanks,
Carlos
Old Jul 4, 2010 | 12:15 AM
ray jr's Avatar
ray jr
do people with the airaid kit also use the vette air ?
Old Jul 4, 2010 | 09:04 AM
lebvette's Avatar
lebvette
Sure, it will work with any intake.
Larry
Old Jul 4, 2010 | 11:16 AM
seevi's Avatar
seevi
What is the tuning fix? What tables are changed and what are the changes?
Old Jul 7, 2010 | 11:10 AM
mittens's Avatar
mittens
its all in the part throttle. fist you make it go to closed loop sooner, and you change the fuel on the part throttle to get it closer to the 0%. Texas Speed has seen this happen alot with vetts.
To vette air surging
