overheating issues
Old Jul 2, 2010 | 09:41 PM
dvandentop's Avatar
dvandentop
Default overheating issues
over the weekend the car started overheating to the extremes, coolant looks good and so does oil so pretty sure no head gasket problems.
i just replaced the water pump and thermostat and still the same thing.
i am running a dewitts radiator, i have driven the car quite a bit since installing the radiator
fans are coming on also when they are supposed to.
any ideas??
pretty much have ruled out anything cooling system related i am guessing pretty sure no air in the system or it would have shown up well before now.
upper big rad hose is getting hot but the bottom big passener one is not getting warm during engine operation
Old Jul 2, 2010 | 09:49 PM
tomiboy's Avatar
tomiboy
Sure sounds like air in the system. Have you tried removing the small hose going into the driver's side head (it come off a tee by the radiator) and blowing in the coolant reservoir? Keep blowing until water comes out. I had to do this a week ago after a t-stat change that was causing overheating
Old Jul 2, 2010 | 10:18 PM
DONALD HALL's Avatar
DONALD HALL
The LS2 cooling system is the hardest I have ever had to get the air out. I used a minivac hand vac pump and hooked it to the small hose comming form the head to the tank and pulled a vac on it until water came out, I could actually add coolant/water to the tank as I was pulling a vac on the engine. Was able to get all the water that drained out of the rad back in, worked great.
Hay, I see you are from Sioux Falls, SD, I will be there in about 12 days for the BHCC. Are you attending??
Later
Donald
Old Jul 2, 2010 | 10:34 PM
dvandentop's Avatar
dvandentop
i have ran this for a few hundred miles on the track before this problem occured so idk how it could be air in the system all of a sudden
Old Jul 2, 2010 | 10:35 PM
dvandentop's Avatar
dvandentop
i will be at the sf event but wont be at the black hills ones this year. look for my silver z06 with cf deals on the back window
Old Jul 2, 2010 | 11:46 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Originally Posted by dvandentop
any ideas??
Yeah I have one, and your not going to like it. It's possible to ballon the flat cooling tubes if you see pressures 50 psi or higher. This would make the tubes expand and crush the fin so no air could get through the core. It could be a pressure cap or stat malfunction or a blown head gasket.
It's hard to see the effects of this so I'll post both a good fin and a crushed fin. Another way to tell is to drop a piece of paper in front of the core and see if you have any pull.
Old Jul 3, 2010 | 12:03 AM
dvandentop's Avatar
dvandentop
tom the collapsed pic didnt work?
the oil is not discolored so idk any other way to identify that?
Old Jul 3, 2010 | 12:08 AM
glennhl's Avatar
glennhl
Pull the driver's side head coolant line and purge the system by blowing into the tank. Blow until you get water out the line, put the line back on, then top off.
I had the same problem after replacing a thermostat, it's amazing how quickly it overheated due to air in the system.
Old Jul 3, 2010 | 12:34 AM
dvandentop's Avatar
dvandentop
the coolant line you are talking about goes right by the throttle body right?
where do i blow into the tank? also do i have the cap off during this??
Tdewit that is really hard to see the difference in the 2 pics besides a few bent fins on the radiator. so you are saying with the car running before the fans turn on a piece of paper should stick to the rad?
Old Jul 3, 2010 | 01:39 AM
dvandentop's Avatar
dvandentop
tom i can now see in your pic each row has expanded up and down. i will check it out tomorrow and let you know what i find out.
Old Jul 3, 2010 | 07:24 AM
LEAVINU's Avatar
LEAVINU
What kindof temps are you seeing and in what conditions?
Old Jul 3, 2010 | 09:43 AM
haljensen's Avatar
haljensen
You had an overheating problem, then replaced the water pump and thermostat but still the same overheating problem? Could it be that the "problem" was/is just a faulty sensor or gauge?
Or; Since you have no water flow thru the hose maybe your replacement thermostat is not opening?
Old Jul 3, 2010 | 11:06 AM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
You don't always have mixed oil & water with a bad head gasket or a cracked/warped head. Sometimes a connection between the cylinder and the coolant can happen without involving the oil. This might happen only when you at maximum temperature when pushing it hard.
Old Jul 3, 2010 | 11:11 AM
timd38's Avatar
timd38
Could you have put the thermostat in backwards?
Old Jul 3, 2010 | 11:36 AM
dvandentop's Avatar
dvandentop
temps are getting to 210 or so sitting in the garage after around 2 minutes running.
fans ran on high speed but are not bringing the temp down.
i tested out both old and new thermostat and they both opened up fine when up to temp by dropping them into hot water
can only go in onw way and there is an alignment tab
Old Jul 3, 2010 | 01:42 PM
Whisky's Avatar
Whisky
210 is not even close to overheating. What happens when you run down the road or push it hard?
Old Jul 3, 2010 | 03:29 PM
dvandentop's Avatar
dvandentop
250-260 when i was on the road course and it was purging fluid at a track day.
it has been to the track 4 days previous to this with the new radiator and now issues so something has gone bad it seems.
To overheating issues
Old Jul 3, 2010 | 05:23 PM
dkal70's Avatar
dkal70
Check to see there's nothing in front of the a/c condenser or any obstruction blocking the air flow through the condenser to radiator.
See if the air dam is okay.
Old Jul 3, 2010 | 05:28 PM
FU's Avatar
FU
Race Director<br><img src="/forums/images/ranks/7k-10k.gif" border="0">
From: HOME OF THE FREE. BECAUSE OF OUR BRAVE. Babylon NY
St. Jude Donor '06 thru '20
Do a compression test.
Old Jul 3, 2010 | 06:03 PM
dvandentop's Avatar
dvandentop
tom just checked out the fins and they all look fine, i guess compression test is next.
dkal all is good down low for no obstructions etc..
going to try 1 more flush and without thermostat to see what i can find.
