Thoughts on header coating???
Old Jul 3, 2010 | 05:50 PM
scottss's Avatar
scottss
Default Thoughts on header coating???
I just got a '10 GS a6(daily driver) and the mod bug is nearing. I plan to get 1 3/4 headers with high flow cats...intake, tune and axle back...I had a Trailblazer SS with coated headers and all was fine. I have heard different opinions about whether or not is is truly necessary to coat the headers. Now that I am on a CORVETTE forum, I can get REAL opinions on coating ect.
Also, should you replace wires and plugs?
Thanks in advance!!
Scott
Old Jul 3, 2010 | 07:01 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Thanks in advance!!
Scott
The only reason to coat them is for looks, and after 5 years, they all look the same, so it depends on if you care about such things for car shows, and how long you plan to keep your car.
I have had uncoated headers for years now, and they hold up perfectly and there are no heat issues in the engine compartment.
Old Jul 3, 2010 | 07:31 PM
FU's Avatar
FU
Race Director<br><img src="/forums/images/ranks/7k-10k.gif" border="0">
From: HOME OF THE FREE. BECAUSE OF OUR BRAVE. Babylon NY
St. Jude Donor '06 thru '20
Swain coating. Nice thick ceramic coating. It works.
http://www.swaintech.com/
Old Jul 3, 2010 | 07:39 PM
MPM IV's Avatar
MPM IV
Depends on the header. Many headers are now made from stainless steel because they retain the heat much better. Some are still made from mild steel, which will rust quickly and not hold the heat in, resulting in higher underhood temps.
I wouldn't coat stainless, I would coat mild steel.
Old Jul 3, 2010 | 07:48 PM
had2have-it's Avatar
had2have-it
Coating stainless headers causes problems or is unnecessary?
Old Jul 3, 2010 | 09:49 PM
NJLS708's Avatar
NJLS708
Its unnecessary, however if you are putting headers I do recommend changing your wires. The stockers tend to not hold up under the additional temps.
Old Jul 3, 2010 | 10:03 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Without a blower, my stockers have been fine for 8 years over 2 vettes.
Old Jul 3, 2010 | 10:09 PM
NJLS708's Avatar
NJLS708
Mine were ok also but when I added my blower my tuner advised me to swap them out.
Old Jul 3, 2010 | 10:20 PM
LS1LT1's Avatar
LS1LT1
Personally, I left the factory/stock plugs in until they got some miles/use on them because I'm a thrifty guy and like to maximize these things LOL but there are better ones (NGK) out there.
Plug wires, I would only change them out for another set of the exact same OEM stock ones once the originals got too old/too many miles on them.
Old Jul 3, 2010 | 10:33 PM
miwung's Avatar
miwung
I bought a set of LG super pro's for my z. I had them jet-hot coated (sterling silver) last month. I can tell you that they definitely bring down the overall eminating from the area where the headers are, plus they look beautiful. I had the headers, xpipe and cats done. I've seen tests done with a gun to measure the surface temps of coated and uncoated headers. They appear to do what is advertised. I didn't see it with my own eyes, so who really knows for sure if it's 100 percent worth it. I can post pics if you like.
Old Jul 3, 2010 | 10:58 PM
LS1LT1's Avatar
LS1LT1
It is possible that the coating brought down those temps by a lot.
If you'd like you can try this experiment to know for sure, drive around in stop & go traffic with a few highway blasts for about an hour or so and then stop and immediately pop the hood and grab a hold of a couple of those coated header primaries for a minute or two and then let us know.
That was a joke, kids do not try this at home LOL.
Old Jul 3, 2010 | 11:02 PM
miwung's Avatar
miwung
I doubt it was a lot, just seemed that way....maybe it was my head trying to justify the extra money I spent. If it really didn't work, I'm not sure how a company that does coatings stay in business. It's got to do a little bit! no?
Old Jul 4, 2010 | 01:08 AM
YLOFEVR's Avatar
YLOFEVR
St. Jude Donor '09-'10-'11
Default Headers coating
There have been several instances mentioned on the Forum and elsewhere that have told of problems with headers coating in that they have cracked near the primaries. The problem was recognized as being a difference in the heat expansion of the metal as opposed to the ceramic coating. Many owners have chosen to use some of the high quality interior insulation available from several Forum vendors to preclude heat infusion into the cockpit/interior but this, of course, does not address the heat radiating near the engine.
Old Jul 4, 2010 | 03:06 AM
LS1LT1's Avatar
LS1LT1
Yes, it should definitely reduce the temps of the headers to the touch by quite a few degrees for sure, it's just that some have argued whether that's even a truly good thing or not.
Something about the flow/velocity of exhaust gases exiting the motor or something.
The stainless headers that have been on both of my cars aren't coated and I likely won't have any stainless headers that I might buy in the future coated either.
The coated ones do look pretty though.
Old Jul 4, 2010 | 03:20 AM
3 Z06ZR1's Avatar
3 Z06ZR1
Thanks in advance!!
Scott
Lots of reasons to coat them!
1. Heat reduction in engine compartment. Less heat on your plug wires and wiring.
2. better savaging due to heat staying in.
3. Looks better plus your headers will last longer.
4. Coat stainless as well for the same reason's
5. Won't put on a set of uncoated headers.
6. Jet hot is the BEST!
Forget the 1 3/4 for your GS get 1 7/8's! Plus 3 inch X-pipe!
Old Jul 4, 2010 | 07:00 AM
timd38's Avatar
timd38
I have Billy Boat headers and they told me that I wasting my money by coating them. That being said, I plan to coat them this winter.
Old Jul 4, 2010 | 12:38 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
took the words right out of my mouth
To Thoughts on header coating???
Old Jul 4, 2010 | 12:43 PM
scottss's Avatar
scottss
I thought that you would actually LOSE power going 1 7/8 if you are not adding power adders or head or a cam.............
Old Jul 4, 2010 | 02:30 PM
NYC6's Avatar
NYC6
You're right. The larger tubes hurt tq in the heart of the powerband. Thats right where you wouldnt want to lose it. There have been tests performed on S/C'd cars and the difference is minimal and not worth the effort. On a stock engined car hp/tq loss would be substansial. I have 1 3/4 LG Pros on my 522rwhp are they perform great. They are not coated either and my cabin stays nice and cool, and the heat in the engine compartment doesnt get to hot either. I wouldnt bother coating SS long tubes.
Old Jul 4, 2010 | 03:54 PM
Streetk14's Avatar
Streetk14
I've been there and tried both ways over the years. I've had ceramic coated headers and raw stainless. I cannot say much about the possibility of improved performance with the coatings, but I think the raw or brushed stainless holds up better and is easier to keep looking nice. Ceramic coatings like to stain and discolor if anything spills on them. Raw stainless can be restored with scotch-brite and WD40 if it ever needs some freshening (as per Stainless Works).
I also think that ceramic coated headers look out of place in a modern car's engine bay. I'm in California, and like my headers to blend in, too . For what its worth, I went with LG Super-Pro 1 3/4" headers w/ cats on my cammed '08 LS3 car. I didn't want to give up the extra long primary tubes and torque by going with 1 7/8" headers.
Oh, and one other thing. I'd recommend picking up one of the ceramic/stainless starter heat shields from Lingenfelter (http://www.lingenfelter.com/mm5/merc...egory_Code=E15). I've seen starter terminals/cables melt over time on LSx cars with headers. The Lingenfelter heat shield was cheap insurance for me, as I am trying to keep my car as reliable as it was when stock.
Andy
