Thermostat Question
Old Jul 7, 2010 | 07:40 PM
Joe's C6's Avatar
Joe's C6
Default Thermostat Question
I am a new vet owner, considering changing to a 160 or 180 Thermo. Have read where I will need to have PMC changed. I called 2 GM service locations in my area. 1 said the tech certified to do it is no longer employed. The other told me that nothing could be done to change anything related to the fan and if it is changed it would effect the warranty. So my question is when changing the thermo do you need to have the PMC changed and where to you have that done in the Indiana area.
Old Jul 7, 2010 | 07:59 PM
lebvette's Avatar
lebvette
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
The 160 will cool you down on the highway, but not in red-light traffic unless you program your fans to come on sooner. Reprogramming the fans would be messing with your computer and could void a warranty.
Get with the local Corvette club. They will know someone that can do your fans if you wish.
Larry
Old Jul 7, 2010 | 08:07 PM
Joe's C6's Avatar
Joe's C6
thanks for the quick response
Old Jul 7, 2010 | 08:51 PM
Robls6's Avatar
Robls6
There's no point in changing the stock stat if you aren't doing anything else to the motor.
Old Jul 8, 2010 | 02:07 AM
Rebel 1's Avatar
Rebel 1
It's a piece of cake to change, you can easily do it yourself. I wouldn't consider the 180*, you have a 187*. I put a 160* stat in our '09 and very satisfied with the results and you don't have to change anything else. Don't have to reset any fans unless you want cooler temps while stopped. Used to run 191-196* cruising now 172-176* which is where i like it. Enjoy your increased power
Old Jul 8, 2010 | 04:42 PM
Bill Dearborn's Avatar
Bill Dearborn
Any increase in power at those temps is incremental at best. Once you start running hard the coolant temp is determined by the cooling capacity and not the thermostat which just sets a floor on the temperature and does nothing about the ceiling. A wide open 195 degree thermostat flows just as much coolant as a wide open 160 thermostat.
Bill
Old Jul 8, 2010 | 05:04 PM
TARANTULA's Avatar
TARANTULA
Bill
Agree but the 160* thermo will give the system a better fighting chance. A head start if you will. Just my opinion
Marcos
Old Jul 8, 2010 | 05:06 PM
Rebel 1's Avatar
Rebel 1
Bill
Our '09 has shown power gains i can feel with the 160*. C5/C6 cooling system is good enough for street and some drag racing. It doesn't matter how hard i run the temp never goes above 186* and runs 172-176 cruising. 195 stat wide open flows as much coolant as 160 wide open. Yep, know that.
Bob
Old Jul 8, 2010 | 07:27 PM
haljensen's Avatar
haljensen
160° t'stat will make a power difference. The ECM pulls ignition timing with coolant temps above 195°.Betwen the ECM pulling timing for intake air temp and for coolant temp you can lose LOTS of HP.
Old Jul 9, 2010 | 12:46 AM
Rebel 1's Avatar
Rebel 1
To Thermostat Question
