Changing rear axle /diff oil
Old Jul 10, 2010 | 08:19 AM
Pintobay's Avatar
Pintobay
Default Changing rear axle /diff oil
Here is a response from a question last week -
My 06 did the same as yours at about 10K miles. Changing the lubricant took care of the problem and I have had no clunking, creaking, banging etc ever since. I am now just about at 30K miles. If you are interested in doing the change yourself, there is an exellent DIY by senior member Vet. Do a search of FAQ under "DIY - rear axle/differential oil change, with pics" and it should come up.
I cannot seem to locate this post about changing the oil - any help will be appreciated.
Mike
Old Jul 10, 2010 | 10:28 AM
Robls6's Avatar
Robls6
It's easy. Jack the car up level so you can get underneath it and drain the oil out of it. Replace the drain plug and just pump new fluid into the fill hole until a little bit starts to run out the bottom of the fill hole. The car needs to be level to make sure you are not over or under filling it though.
Old Jul 10, 2010 | 07:24 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Mike
Go to C6 General Discussion, look at top of forum for "Sticky: C6 FAQ - New", click and go to category "FLUIDS and MAINTENANCE" where you will find "Tranny & Rear Axle Oil Change DIY"
Old Jul 11, 2010 | 06:40 PM
ALS 08's Avatar
ALS 08
Suction Gun.
Used one of these to fill Axle. Drawing fluid direct from bottle with it wasn't working to well so I unscrewed one end of gun and filled it with Amsoil. Worked like a charm.
$10 or so at local Auto parts.
Old Jul 11, 2010 | 10:30 PM
JoesC5's Avatar
JoesC5
Loosen the fill plug before you remove the drain plug. The last thing you want to do is drain the oil and then find out you can't get the fill plug out. I originally replaced my transmission fluid in my 09 Z06 with RP and it made the nibbles/grinds in the 1-2 & 2-3 shifts worse, so I dumped the RP and replaced with Mobil1 ATF III. At first, I couldn't see any improvement, but now at 9,000 miles, while it's still nibbles/grinds when its cold, it's really smooth shifting when hot(very hot). I didn't change out the rear end oil as I've never experienced any clunking, etc.
Old Oct 10, 2010 | 05:51 AM
nch209's Avatar
nch209
No jack needed... changed mine in under 10min...
Old Oct 10, 2010 | 06:48 AM
timd38's Avatar
timd38
I have lift and didn't need a jack either, but not sure how you got under it to do.
Old Oct 10, 2010 | 07:47 AM
Squishy's Avatar
Squishy
Be extra careful about the clip on the diff line. Might buy an extra in case as mine popped off while loosening and I got lucky finding it like 10 ft away.
Old Oct 11, 2010 | 12:54 AM
nch209's Avatar
nch209
I just pulled it in the garage , tossed cardboard down and spun out the top then bottom plug- drained- then pumped new oil in via a pump from autozone that spins right onto the oil bottle. No ramps, jacks, lifts- nada. Sure, a lift woulda made it VERY easy though...
Old Oct 11, 2010 | 12:55 AM
nch209's Avatar
nch209
May be a dumb question on my part- but what exactly are you speaking of? Clip???
Old Oct 11, 2010 | 07:23 AM
GOLD72's Avatar
GOLD72
If you have a Z06, ZR1 or a vette model that shares that diff cooler and circ pump arrangement, the diff housing is actually drained by removing the circ pump suction line from the bottom of the diff housing. There is a easy disconnect fitting that is held together by a wire type preformed spring clip. I understand that it is the same clip part number used commonly elsewhere on transmission/hydraulic oil lines on the vettes as well as other GM cars. Ignore this if your diff housing doesn't have a circ pump and cooler.
Old Oct 11, 2010 | 08:51 PM
nch209's Avatar
nch209
Gotcha... THANKS!~!!!
To Changing rear axle /diff oil
