Tranny Reverse gear grinding or Clutch problems please help??
i have a 2008 corvette c6 6speed manual.
about 3 weeks ago after i did a clutch fluid change myself via the ranger method i started experiencieing some reverse problems.
my car is PERFECT in gears one thru six. but when i put it in reverse when i wanna back out of the driveway it makes grinding sound for 2 or three trys. if i put it in 3rd then in reverse it will be fine.
is this because there is air in my system or because my reverse syncro is bad?? or could my clutch be warped or something?
i need opionions or if this has happened to anyone else
thanks guys
thanks guys
I have an 08 Z06 and that was the beginning of the end of my tranny. I could not get into reverse without the gears grinding like I didn't know how to shift. Dealership told me there was nothing wrong with tranny. I kept using the car until one day the car would no longer go into reverse. Then GM replaced the one synchro. As soon as I got the car back from dealership, 3rd and 4th gears started grinding. called dealership and GM made the decision to replace tranny. New tranny works great. no more problems.
I am having the same exact problem, shop just did new clutch in car and everything ran fine for month. Then all of a sudden started grinding when tried to use reverse. If I want into first gear and then reverse problem does not happen. Any ideas?
07 zo6
Just to let you all know I called five different chevy dealerships and talked to the service dept. All of them told me its normal for reverse to grind,,, if you dont wait a couple seconds after applying the clutch. They said reverse isn't synchronized, need to let flywheel slow down, or put in different gear before going into reverse. One guy in service talked to his tranmission man and he also said its normal, One did ask me how quick did it grab when i let off clutch,,,incase there was problem with clutch...I suggest some of you called chevy dealer and ask like i did see if you get the same answers, and post it for us to see what you find out. my does fine if i count to like five after applying the clutch, then put it in reverse. Verry weird!!
I've got this problem right now in my 2008 C6 with 8200 miles.... My car is in the shop for an indefinate amount of time at this point becaue i am being told GM has no 6 spd transmissions in the US for my car!
Long story short:
I heard the grind in the AM had no reverse by late Afternoon the same day!
The long story goes as follows:
I bought this car used on 7-22-10 (less than 30 days ago), The car was amazing and perfect, but at the time of purchase i noticed a little noise coming from the transmission that sounded like a throw out bearing but i was ASSURED by the mechanics at the dealership that the noise was just the typical marbles in a can noise associated with this tremec transmission. I figured the noise was ok listened to the guys who had a better idea than me and just figured i would deal with it as this car is practically a street legal racecar. The bad news came 7-25-10... Three days after i signed the contracts. Sunday Morning i went out to meet some friends at the pool. When I got in the car in my driveway at home and went to put it in reverse i noticed it had a grind... this was the first time i ever noticed the grind something i wouldn't have missed prior.. 5 or 6 reverse attempts later throughout the day all returned the reverse grind noise... Finally number 7 reverse was gone.... i was in a parking lot trying to back out and found i had NO reverse...
I took the car to the shop monday 7-26-10... where its been untill now! 8-23-10 while van chevrolet in dallas trys to locate a 6 spd transmission. The word is from them that there are no 6spd transmissions anywhere in the united states! I dont know how true that can be at all or if anyone on the board has the ability to check that statement because its been 4 weeks and i still have no car
Update:
The noise turned out to be the reverse gear itself had split in half.. the gear was missing teeth ( probably because its not syncronised because this trans only has 8200 miles ) and the gear was cracked in half... GM's remedy is to replace the transmission thankfully.. however GM has no transmissions in the US to replace it with? Is this scenario even possible???
Long story short:
Update:
After reading a lot of posts on tranny problems for 08's and up I wonder if the T6060 was really an upgrade. I know there are/were issues with the T6060 in Mustangs too! It's purely anecdotal but it seems like this reverse grinding issue plagues a lot of these new T6060 trannys...
Todays update:
GM may have found a surplus transmission after i called customer service hotline... i'm pretty sure the dealership should have done this a week ago... but i did it myself and got an answer within 2 hours....
We'll have a deffinate answer by wednesday...
Received 8,930 Likes
My 08 tranny doesn't do it but the tranny's in my 2 C5s did the same thing. All I did to prevent the grinding was to hold the shifter in 5th and slowly let the clutch out until the gears meshed. When they meshed the shifter would move forward just a little more. Ran for years and many thousands of miles like that with no more grinding and no other issues. Didn't have to shift to another gear or anything else. If you let it grind you probably will have a problem at some time in the future but doing this procedure prevents it from occurring.
Bill
Bill
1 Post
St. Jude Donor '09
My 08 grinds 5th if I do not slowly slide into it. My 08 always had notch shifts when cold outside. After a few miles of driving it gets better. 6060 not my favorite trans so far.
I got mine back, and the shifting feels better in all gears. In comparison, it took a lot more effort to get into reverse before the repair. I'd highly recommend you take it in and let them address the issue under warranty.
Bill
Bill
I simply depress and hold the clutch, pop it in 3rd (just to ensure I don't mistakenly put it in reverse by finding 5th), then put it in reverse and slowly release the clutch. I never hit the gas until it has fully meshed. Sometimes I'll even see the shifter get sucked into reverse while slowly releasing the clutch.
