ring and pinion swap
Just a suggestion for you, the Z51 gearing is a little to steep for a 4.10 in my opinion. With a stock tire you cannot run out the 1/4 mile in forth with them, and first gear is to short.
We recommend, and have swapped others from 4.10's, to 3.90's.
We can do this while you wait, using your carrier, and replacing any parts necessary. Clutch packs, hardened shafts if necessary and so on.
Our standard price for the gear swap is $1,395, all labor included, and takes roughly four to five hours.
Thanks, Doug
C5/C6 and C7 Supercharging Specialist
ECS Supercharger Kits / Mantic Clutches
www.EastCoastSupercharging.com
Facebook Page
ECS YouTube Channel
If you're in the market for a Corvette Getrag diff,
We've got what you need.
We can build you ANY diff with several options available.
Auto or stick including C6ZO6!
Call us any time!
Chuck CoW
a normal gear swap is 400-500 bucks. but becasue most dont haev the tool that make it easier they charge a **** load. no offince vendors.
) 500 rpm bump in the rev limiter would get ya across the line in 4th if you were at the drags.Listen, if you're a really serious drag guy, you'll just have to do the math or test it out with your combo.
If you're a street guy wanting the best bang for the buck, I don't think that you'll find a shop that has installed more 4.10s in ALL year vettes than us....
So much so that our competitors like to make fun of us for it!
What the heck! It WORKS and makes the customers SMILE!
Chuck CoW
Most installers do not do that, along with the specific tools needed, and the removal of the entire rear cradle compared to a std straight axle which just removes a cover and your started. There's a big difference between the Vette rear and most others. Especially someone coming from older car experience.
Being educated on this, I take no offense at all to it.
Be careful taking advice from shops that do not have any track experience, you will regret it in the long run. Being in the area, take a run down to NJ Motorsport Park tomorrow if your available, we have an ECS sponsored track day for our customers going on there. You can get sound advice on the subject from those who know best, the ones that are there doing it regularly if thats the direction you would like to go.
btw, Raising the rev limiter to 7100 on a stock engine/springs will absolutely cause you a failed engine at the road course, be careful...
You can get your gears from whomever but what are you really getting besides a quote?
So back to me - I loved 3.73s with my h/c and it wasnt until I put in a LS7 with 570 rwhp/ 540 rwtq where I found 3.73 not to work for me anymore. In the middle of the uphill esses at WGI I had to make a shift change otherwise I was hovering around redline. I was able to make the shift, but I knew each time I did if I made a mistake and disrupted the balance of the car there was a chance I could end up in a wall. It wasnt until after VIR that I decided 3.73s no longer worked for me. I still loved them on the street and if my car was mostly street driven I would have dealt with the 3.73s, but since my car sees 15-20 track days per year I moved to 3.42s. Now coming through the uphill esses at WGI I can be in 4th gear and whine the car out focusing on driving not trying to figure out where to shift. Honestly I barely hit 160s on the back of WGI with the 3.73s, but with the 3.42s I can do it and I am still only in 5th so a single downshift to 4th for the bus stop (or if I am adventurous I rev the **** out of the car and jump from 5th to 3rd).
BTW - years ago I added up the additional shifts I needed per lap and then calculated how many laps I would do in 4x30 min sessions. The amount of extra shifts needed with 4.10s was incredible.
Again I am not saying 3.42s are the best gear for every track, but most of us do not have the ability to change gears for each track so I found the gearing that I liked for the tracks that I go to most. For the tracks I visit less I make do. I am telling you this from my own first hand experience (check out some other tuners who never been to a RR track with their car and as matter of fact dont even own a vette
) so take it for what you feel it is worth. any help feel free to ask.
I can show you a video with Doug and I at VIR. He has a 402 running over 500rwhp/rwtq with 3.42s, but with MN12 while I was running the 3.73s MN6 with 460rwhp/401rwtq. There are places in the video where you see me actually pull away from Doug because he cannot utilize the lower gears (remember a mn12 with 3.42s is like a mn6 with 3.90s gears 1-3) and I can. On the back straight where he now has 3.42s and I have 3.73s he pulls pretty easily, but of course this is when he can get all the power down to the ground.
I'm doing 3.73s on my Z51 HC LS2, mostly street driven, rare track days if I ever have the time and canyon runs once a month. I can see from running in the canyons that anything lower with an MZ12 wouldn't be so much fun on a track.
I also agree that the extra shifts on a track would eat up too much time, especially so in my case because I still suck at shifting this car smoothly.
as far as ruin your fun on the track I doubt that could happen but I didn't want you to think your lap times will decrease because you have 410s. Yes 410 have helped many decrease ETs in the 1/4 but we know there is much more to putting together a fast lap for RR than one straight away.
So are there other things you can do to make yourself faster well that depends on your current mods and your ability but I can say from what I have seen all of us on a RR track has room to go faster just finding those areas is the challenge.
I personally just bought traqmate data acquisition system to find my areas which need improvement (I am done modifying my car at this time so it has to come from me improving). Modifying your car might not improve track times It might just come down to you needing more track time.
As am example a friend of mine has same power and basically same setup I have. On the front straight of WGI he asked why was I able to catch him and pass so quickly. I said because I am exiting the turn onto the front 10 mph quicker. So you see having power doesn't mean you will be the fastest car (it does help though).
If you haven't yet venture over to autos/road race section of corvette forum. Post your mods and your skill level. There are plenty of guys over there much better than me who can help direct you in the right direction.
