Installed a RPM differential
Old Jul 18, 2010 | 05:30 PM
baxterboy's Avatar
baxterboy
Default Installed a RPM differential
I installed a 3.42 differential in my 2008 s/c C6 A6 vette. Got a (efi live based) tranny tune from ECS and tranny shifts great. Only problem is that the speedo is out to lunch. I tried with EFI live to switch the speedo calibrations but when I put in my tire size, final gear ratio (3.42) the check engine light and speedo was out a pile more (showed me going 30 MPH pulling out of the driveway). Any advise on how to get my speedo close to accurate? My car is an automatic. Looking at the tune file it shows final gear ratio of 3.42 but all the other values are the same as my 2.56 tune (IE sensor, revolution, Ect.)
Old Jul 18, 2010 | 05:39 PM
RicK T's Avatar
RicK T
Don't have an answer for you. You might want to also ask over in the Scan and Tune Forum. Might be someone over there who knows what's going on. Good luck.
Old Jul 18, 2010 | 08:47 PM
EuroRod's Avatar
EuroRod
RPM should have an answer I'd think?
To Installed a RPM differential
