oil pressure senser
Old Jul 20, 2010 | 11:52 PM
Timothy Barth's Avatar
Timothy Barth
Default oil pressure senser
I have recently noticed wide fluxuations in the oil pressure readings. It will vary from 50lbs to 84.How hard is it to replace the senser if that is the problem.It is a 2005 LS2. Also this car is still on a extended warrenty.Should I dare let Chevrolet fix this?
Old Jul 21, 2010 | 04:35 AM
calemasters's Avatar
calemasters
The labor time guide states 1.4 hours. You have to remove the intake to access the sensor.
Old Jul 21, 2010 | 07:49 AM
Timothy Barth
The intake manifold?
Old Jul 21, 2010 | 08:35 AM
haljensen's Avatar
haljensen
Yep, the oil pressure sensor is on the rear of the valley cover under the back of the intake manifold.
Old Jul 21, 2010 | 11:21 AM
bobbyd99's Avatar
bobbyd99
I just replaced mine on a 2006 and it is much easier to use the cut hole method. I got the new part which was defective and after getting another one from Rock Auto it was very easy to replace. There is a post on the forum that shows you where the sensor is located and where to cut the hole. If it should go again it will be a 30 minute job.
Good luck.
Old Jul 21, 2010 | 02:11 PM
Timothy Barth
Good luck.
I have tried to access this post and cannot find it .What is it under?
Old Jul 21, 2010 | 02:35 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
I gotz search skillz!
http://forums.corvetteforum.com/c5-t...sure-unit.html
See post #7
Elmer
To oil pressure senser
