Vararam high temp problem solved!
Old Jul 23, 2010 | 11:23 AM
Dogleg09's Avatar
Dogleg09
Default Vararam high temp problem solved!
First, thanks for everyone's replies, one of them made me think of something that may have been the problem. Last post I mentioned that I had a Vararam installed and I was seeing water temps of 220-225. Well, I remembered that I saw the installer insert a board behind the shroud to make the cut out. Yes, you guessed it, he LEFT THE BOARD BEHIND THE SHROUD COVERING THE RADIATOR!. Of course I called the installer to let him know that if he couldn't find his "cutting board" it is because I have it in my garage.
Old Jul 23, 2010 | 11:28 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Oopsie! It was a test to see if you had detective skillz!
Elmer
Old Jul 23, 2010 | 11:30 AM
LS1LT1's Avatar
LS1LT1
Yeah I knew it had to be something else, there's no possible way that a (properly installed) Vararam alone can raise coolant (or oil) temps that much.
Glad ya got it figured out.
Old Jul 23, 2010 | 04:07 PM
VaraRam Industries's Avatar
VaraRam Industries
Supporting Vendor
St. Jude Donor '07-'11-'12
We do tell people to put something behind the shroud to protect the condenser when they are cutting but this is the first I have heard of someone leaving it!!!!!!!
Old Jul 23, 2010 | 05:00 PM
eboggs_jkvl
Moderator emeritus
I think it is absolutely your fault. Your instructions say to put something behind the shroud to protect it BUT...
Do your instructions say to "Remove it when finished"? Hm..... I rest my case.
Elmer
Old Jul 23, 2010 | 07:53 PM
Dogleg09's Avatar
Dogleg09
Now that I know it is your fault I will be sending a doctor bill for my frustration...
To Vararam high temp problem solved!
