Calling tire Exports - quick question
Old Jul 24, 2010 | 07:01 PM
mfquinn's Avatar
mfquinn
Default Calling tire Exports - quick question
Can you mix run flats with non-run flats? If I keep run flats on the front (until they wear out) can I run non-run flats on the rear without any adverse handling issues? Just found a screw in one of my rears and will be heading to Road Atlanta in two weeks and am not sure what I should do. The rears are getting close to replacing anyway so I don't want to patch and then track the tire.
Thanks for the help
Old Jul 24, 2010 | 07:13 PM
BearZ06's Avatar
BearZ06
St. Jude Donor '09 thru '17,'22 thru '26
NO, it will not handle right and would be dangerous.
Old Jul 25, 2010 | 09:14 AM
lebvette's Avatar
lebvette
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
Most that have tried it says........NO.
Larry
Old Jul 25, 2010 | 09:26 AM
LSCHLEM's Avatar
LSCHLEM
Are you sure. I have stock RF's on the front and offset + 2.5" inward
11" wheels with 305/35/18 nitti DR's on the back. Car handles well but
should there be a reason I should know about using this setup ?
Old Jul 25, 2010 | 12:01 PM
mfquinn's Avatar
mfquinn
To Calling tire Exports - quick question
