LS-3's need to worry!
Old Aug 5, 2010 | 07:11 PM
dennis50nj's Avatar
dennis50nj
Originally Posted by ninjavette
And by that logic a geared 2011 5.0 with a tune and catback better watch out for a geard LS3 with a tune and catback. Not to mention a bolt-ons or cam'd LS3.
That 5.0 is definately quick for those little mods but the LS3 can be too. If we're comparing stock to stock, a GT 500 vs LS3 will be a driver's race with edge to the LS3. Stock 5.0s aren't a threat. If we're talking modded, well then everything gets thrown out the window because any of the cars can be modded and who the hell knows what you're lining up against. I'll take the Vette all day, regardless of what the Mustang does to beat it. JMO
the vette would win over the 5.0 on the top for sure and the turnslet the mustang race the camaro
Old Aug 5, 2010 | 07:18 PM
ninjavette's Avatar
ninjavette
Agreed. Some forget that the steering wheel can go right and left.
Old Aug 5, 2010 | 07:43 PM
DEV-06C6's Avatar
DEV-06C6
My brother has a 2008 Shelby GT 500. My C6 is 500 at the wheels and his is 500 at the crank. I'm 3300 lbs and change and he's 3900 and change. Both are Verts. I can stomp him in the straights and in the twisties it's not even a race. He's going for a bigger pulley but I seriously don't think it'll make up for 600 lbs and my RWHP vs his SAE Net.
Old Aug 5, 2010 | 08:12 PM
SpinMonster's Avatar
SpinMonster
Originally Posted by c5creech
...you can put lipstick on a pig...still a pig!
One good laugh a day......
Old Aug 5, 2010 | 08:18 PM
SpinMonster
Some guys like vettes and some like mustangs. Its silly to talk about which car does what after its modded because you can make any car fast. My friend's mustang here at 6800 feet can run 9.8's at 142 with a DA of 7500'
http://www.musclemustangfastfords.co...bra/index.html
People buy what they want and drive it proudly customized the way they like it. There are a few Acura integras here running in the mid 9's so dont get caught up with whats faster after its modded. I thought the same way thinking these cars arent reliable or fast and there are guys here running insane times with 800rwhp from a 2 liter engine and the transaxles dont blow up even after 50 track days in 2 years. I stopped thinking you can be the king of the race scene just because its a vette. All that does it makes it that much harder to swallow when a 1000whp 50psi AWD talon waxes your butt.
Old Aug 5, 2010 | 08:23 PM
saplumr's Avatar
saplumr
If I had room in the garage I'd consider the GT 500. At one time I liked the Camaro but the interior is rediculous. Count me as a non Mustang hater.
Old Aug 5, 2010 | 09:12 PM
LS1LT1's Avatar
LS1LT1
Originally Posted by 8850
I haven't seen a stock LS3s run 11s with a 2552 DA even with a tune.
If a bone stock LS3 can run an 11.71 in great air then that same driver/car would very likely also be able to click off at least an 11.99 at 2552 feet, even quicker with a tune.
Also, we don't know how this guy obtained his weather/DA information. I've seen online DA readings vary from handheld weather station readings (taken right at thew actual starting line) by as much as 800 feet. It might've actually been only 1800 feet...or it could even been 3200 feet, who knows. Seeing as how it was done in August in Texas I might tend to believe that it was in the area of 2552 feet.
Keep in mind that I went an 11.1 in late August (well almost, it was September 1st LOL) last year in a bolt ons only C6 LS2 as well so there are a lot of possibilities.
Originally Posted by Tom400CFI
118 trap in that vid tells a story. It's darn close to a base LS3. No different than in the late 80's/early 90's.
Yes but it doesn't tell the whole story though...that car's excessive weight/mass will likely NEVER allow it to accelerate with other 118/119mph cars that weigh 400-500 pounds less. It is it's excessive power that permits it to trap that high...that same horsepower/torque in a base Corvette might be trapping 128mph. Weight (and lack of traction) can kill one's acceleration, stickier tires would help but then again they would also help it's opponent as well.
Exactly.
Old Aug 5, 2010 | 09:22 PM
Tony B4's Avatar
Tony B4
St. Jude Donor '08
Its all about POWER TO WEIGHT RATIO'S!!!
Vette is light....Stang is heavy....Vette slices through air...Stang pushes air....Vette any day of the week.
Old Aug 5, 2010 | 09:26 PM
impactblue's Avatar
impactblue
[QUOTE=ninjavette;1574921837]And by that logic a geared 2011 5.0 with a tune and catback better watch out for a geard LS3 with a tune and catback. Not to mention a bolt-ons or cam'd LS3.
much much cheaper to gear mustangs then vettes...
sct or diablo tuner -300
gear set - 270
installl - 100-250
i think the cheapest ive seen a vette gear swap was like 1700
Old Aug 5, 2010 | 09:34 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Make no mistake, I really appreciate the info about the gains that can be had over stock with the addition of various mods and the efforts of the Forum Members who race their cars.
However I think it's pretty pointless comparing a modded 'this' against a stock or modified 'that' with no form of equalizing/class categories.
What's a new, stock Mustang supposed to do when it encounters a corner other than watch the stock Vette disappear in the distance.
When I 'meet' one of these on the street I usually try to complement the driver on his nice car, but many times he is penile-challenged and isn't of a positive frame of mind.
This is probably faster than either the new Mustang or the stock Vette, but so what.
Old Aug 5, 2010 | 09:41 PM
LS1LT1's Avatar
LS1LT1
gear set - 270
installl - 100-250
That is likely true, it's also much cheaper to do almost any other modification (except maybe cams swaps LOL) on a new Mustang as well.
I'll even go ya one further, the new GT 5.0 also costs less to buy than a new C6.
But honestly, I didn't know that we were actually measuring which was the better 'bang for the buck' in this particular discussion.
If we're going down that path then one can build a used C5 that would wipe the street/track up with a stock or bolt ons 2011 GT 5.0 for far less money as well.
Old Aug 5, 2010 | 10:06 PM
///DarkSide\\\'s Avatar
///DarkSide\\\
St. Jude Donor '12 thru '26
I have a Vette & a Cobra - they're both fast - I'm a "Car Guy" first - there's always someone with a faster car
Old Aug 5, 2010 | 10:19 PM
  #33
GeistC6's Avatar
GeistC6
Originally Posted by spinmonster
i stopped thinking you can be the king of the race scene just because its a vette. All that does it makes it that much harder to swallow when a 1000whp 50psi awd talon waxes your butt.
qft
Old Aug 5, 2010 | 10:21 PM
  #34
c6 batmobile's Avatar
c6 batmobile
No mustang will ever be as sexy as the vette. You can make it as fast as you want. Im still not gonna buy one.
Old Aug 5, 2010 | 10:23 PM
  #35
impactblue's Avatar
impactblue
well i think the comparision is new cars with bolt ons... in which case, i personally think the new series of mustangs has everything else out there beat in terms of price/power/performance. you can throw modded z06 out there.. but its still well above mustang territory and that gt500 with the difference to a z06 gets pullied/tuned and probably new rubber.. i could take it further and play both sides but i think my few words should suffice.
ill end it with this though... 30k and choice of a new 5.0 or used c6..
vette every day of the week (even holidays)
Old Aug 5, 2010 | 10:29 PM
  #36
ninjavette's Avatar
ninjavette
gear set - 270
installl - 100-250
True but bringing price into the discussion opens up an entire new can of worms. Are we setting a budget cap on car price and mods? What about used vehicles? $ to HP arguments could go on forever without some set of rules. And in the mod game, there are no rules. Run what you brung!
I'll put it this way. If I get beat by a cheaper car, I won't care. I purchased the car I wanted regardless of what may be more capable for less money.
Old Aug 5, 2010 | 10:31 PM
  #37
AirBusPilot's Avatar
AirBusPilot
More scary mustang ghost stories for the kiddies to worry about.
To LS-3's need to worry!
Old Aug 5, 2010 | 11:17 PM
  #38
LS1LT1's Avatar
LS1LT1
I love them both as well, I've had four Mustang V8s and currently have a Camaro Z28 along with my C6 and can fully appreciate all of them.
I do love the new Mustang GT 5.0 and have been remotely/distantly considering adding one to the stable but that's the dilemma I'd have...how can I drop a full $32k+ on a new 3600 pound Mustang when I might be able to get a much lighter, even more powerful 2008 or 2009 C6 for only a little bit more. I certainly don't need two C6s at the same time either but it's just a value thing I guess.
Old Aug 5, 2010 | 11:46 PM
  #39
Vetteinplano's Avatar
Vetteinplano
I think the 2011 Mustang Gt500 is a fine looking ride.
Hey, a great driver in a Mustang will usually always beat a poor driver in a Vette.
They are both great cars!
Practice, practice, practice.....
Old Aug 5, 2010 | 11:54 PM
  #40
LS1LT1's Avatar
LS1LT1
True.
But then again a great driver in a Cobalt SS will beat a poor driver in a Corvette as well LOL.
