Breathless Perf. Vortex Intake
http://cgi.ebay.com/ebaymotors/ws/eB...%3D1&viewitem=
40HP? Puuuhhhhleeaassseee......
YOU HEAR IT SUCK UP THE AIR WHEN YOU ARE ACCELERATING
NO SURGE PROBLEMS.....
LOOKS GREAT AND WORKS GREAT
GO FOR IT AND GET IT
BUY IT NEW FROM BREATHLESS FOR A FEW BUCKS MORE....... AROUND $515.00
I bought the Vortex Intake from a forum member for $275.00 used. Took the VaraRam off. But I haven't redynoed the car yet. I would say that Vortex is a little smoother at idle. SOTP is about the same.
Something a lot of people don't realize is that GM does actually does things right, even with stock parts and especially with the LS3 and LS7. A perfect example is my car in that I ran a 9.950 with stock LS7 injectors, stock air intake, stock intake manifold and stock halfshafts. Heck, I was even running with smaller LS2 headers which are probably equivalent to a stock LS7 exhaust.
I subsequently upgraded my injectors to 60lbs (reflowed LS7 injectors from Jeremy Formato) but that was only to give myself a little bit more breathing room as my IDC (Injectory Duty Cycle) was peaking around 95% at the track.
In reference to the .04 seconds, the reason I mentioned doing the swap at the track is because most people try to report timeslip improvements from different days which really makes the data unreliable. Since DA differences can otherwise make the same car run 2-3 tenths quicker (or slower) from one day to the next, saying something like "my car ran so much quicker with this mod" doesn't mean anything if the data was not all collected at the same time.
As for the surging, if you've got an LS2 then you probably won't have an issue as the LS3/LS7 MAF is considerably more sensitive to airflow turbulence, so much so that I believe Halltech had to create a diffuser to counteract the problem.
I replaced my engine and went with a 100mm Maf so I got a different one.
Im going to go for it! But I will wait to bid until the end of the auction and do a last minute bid.. hopefully get it for a decent price.
