Just found that under the rear of car (not sure what this body piece of car is called, its black), there's bolts/clips missing that hold the underbody (above exhuast, to the body of the car.
I'm trying to see where to go to find the clips that keep the black underbody piece, to car (the peice that has reverse lights running to it) This is the peice that's missing the clips to hold it to car. There's two holes that push through the rear so I'm thinking this is where I'd put two bolts. Will this work? WWYD?
The rear black underbody peice that hosts the reverse lights. That part has popped out a little bit leaving a gap. So I push it back into upper rear body panel of car. I'm looking for pictures of someones underbody at this location to know what I need to buy to keep the part from moving.
two bolts in the center above the mufflers, push in clips that are molded in along the top and 4 or five bolts along the outer ends. fanstock clips over the lower rear fenders is what the bolts go into
