Cam install question
Old Aug 18, 2010 | 09:44 PM
c6 batmobile's Avatar
c6 batmobile
Default Cam install question
Im putting in a new cam in my 05. I seen information where is says to put the cam/crank alignment dot to dot and others where it says crank dot a the 12 position and the cam dot at the 6 position. Can anyone verify this for me? Thanks.
Old Aug 18, 2010 | 10:09 PM
chevpwr's Avatar
chevpwr
Cam on top at 6:00 and crank on bottom at 12:00 = dot to dot
Old Aug 18, 2010 | 10:13 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
its dot to dot, then turn the crank by hand around until they line up again, recheck, Dont force it..
http://www.ls1howto.com/index.php?article=23
Old Aug 19, 2010 | 08:39 AM
c6 batmobile
I realized as I was going to bed that dot to dot is 12 and 6. I had heard that the cam dot was supposed to be at the 3 position. But since there are already several replies confirming that it is supposed to be dot to dot I dont have to worry. Thanks again all.
To Cam install question
