Fast intake question
Old Aug 21, 2010 | 05:09 PM
U Lost's Avatar
U Lost
Default Fast intake question
I have an 08 C6 A6 stock the car put down 383rwhp. Now with a vararam, Lg longtubes, and Lg GT4 mufflers and a tune it puts down
414rwhp.
have a fast 102 and am waiting on a nick williams TB what kind of gains can i expect with these pieces installed and a re tune.
Old Aug 21, 2010 | 05:38 PM
ls3gotcha's Avatar
ls3gotcha
I am suscribed... I am very curious as well.. keep us updates of your results please
Old Aug 21, 2010 | 06:37 PM
c6 batmobile's Avatar
c6 batmobile
reports are about 15-20 rwhp from a fast intake. If its ported it will be worth more.
Old Aug 21, 2010 | 06:42 PM
EuroRod's Avatar
EuroRod
Have the LS2 FAST intake manifolds been redesigned, or do they still require cutting and patching the firewall?
Old Aug 21, 2010 | 06:51 PM
DaytonaFIC6's Avatar
DaytonaFIC6
Sounds about right. You will gain a decent amount all over the power curve also.
Old Aug 21, 2010 | 07:36 PM
bonnevillebill's Avatar
bonnevillebill
sub
Old Aug 21, 2010 | 10:22 PM
saplumr's Avatar
saplumr
I think it's closer to 20-30.
Old Aug 21, 2010 | 10:32 PM
c6 batmobile
Their website says about 15-20. 30-38 is ported. You can search the forum and see the results of a lot of different members. The highest I think was 38-40 from a ported one.
The new 102 does not require the firewall mod to fit any models.
Old Aug 21, 2010 | 10:39 PM
saplumr's Avatar
saplumr
We dynoed my 90 before and after 5 years ago and got 25. It's been removed due to no burst panels. I may go back to a 102.
Old Aug 22, 2010 | 12:02 AM
SpinMonster's Avatar
SpinMonster
His car isnt going to put down 444 with a FAST added. I agree with 25 or so with a ported FAST on a cammed car. Judging by the numbers I think he has an LS3 and that FAST doesnt net as much. Being its an A6, 414 beofre the FAST is already on the high side for his mods. In fact its kind of leading the pack for auto cars (LS3)
Old Aug 22, 2010 | 09:47 AM
C U IN REARVEIW's Avatar
C U IN REARVEIW
how many fast intake choices for an ls2 are there? whats best? do not want to cut the firewall? how much $? how close would a stock ported be to a stock fast? sorry.........lots of questions....just trying to learn a little about intakes before i decide...i have 05 c6 z51,bassani cat back,calloway honker,kooks lt headers...thanks!
Old Aug 22, 2010 | 03:04 PM
U Lost's Avatar
U Lost
Hey spin are my numbers really that high? My only three mods are a vararam, Lg superpros 1 3/4, Lg GT4 catback, no cats. I dynoed 383 with just a halltec killer bee and no tune. My tuner recomended i swich to the vararam because i cut the radiator shroud for cold air with the halltec and he said i should not have cut it with that intake so i switched to the vararam before the tune. I put down 414rwhp and 406 rwtq with those three mods. I have the unported fast 102, i am just wating on the nick williams 102 throtle body to get to my house to have them both installed. I would be stoked with hitting 430hp. also have you heard anything about the 102 throttle body being hard to tune on the LS3 cars. my tuner said they have had a few problems with them on the cameros.
Thanks for your help
Old Aug 22, 2010 | 08:53 PM
PHLGUZZ's Avatar
PHLGUZZ
Default Fast Intake plus mods
I have as fast intake 2007 C6 Z51 6speed manual, LS2
442 rear wheel hp. Here is what I did
Breathless Performance Vortex CAI and ported throttle body. Fast intake,
ARP racing headers, COMP CAM. and HP Tune.high flow cats, borla touring system.
Stock heads no porting work.
BM Shifter
The car is fast enough for me .And it sounds like a real corvette should.
Yes they had to cut the fire wall but a lingerfelter patch kit is available for that and you cant even see were it was done.
That plus 15% for drive train losses figures to 508hp at the motor not counting on the air effect from the cai. That's Z06 territory on a LS2 !
Old Aug 23, 2010 | 09:44 AM
c6 batmobile
there is only 1 now unless you get it used. That is the 102 and you do not have to cut the firewall with it. A stock ported manifold will probably new you around 15-20 hp if its hogged out while the fast when run with a cam has the potential to make about 38.
Old Aug 23, 2010 | 05:17 PM
SpinMonster
BM Shifter
The OP has an auto car and its an LS3. The LS2 FAST makes a bigger difference. He should make about 20hp less just because its an A6.
Old Aug 23, 2010 | 05:18 PM
SpinMonster
I would port it to make the biggest dfference.
Old Aug 23, 2010 | 07:23 PM
C7&7's Avatar
C7&7
The 102 does not require cutting of the firewall. Direct bold on, no other changes.
To Fast intake question
