Rocker Arm ?
Old Aug 27, 2010 | 07:44 AM
CSIXX1's Avatar
CSIXX1
Default Rocker Arm ?
I was wondering I have a LS3 could you put 1.7's on the intake and 1.8's on the exhaust, I have seen this done on other small blocks. The lift on the intake would stay at .551 and the exhaust would jump to .556 would there be any benifit. It would help scavenge the exhaust side better since there is a big difference in valve size.
Old Aug 27, 2010 | 10:20 AM
RamAir972003's Avatar
RamAir972003
Default I would
I would just put 1.8 all the way, should not hurt the motor I would change the springs to....
Old Aug 27, 2010 | 11:27 AM
CSIXX1's Avatar
CSIXX1
I was just throwing that out there I've heard of of it being done, if you did it that way it would save a spring change. I am considering going 1.85 anyway lift will be .600 on the intake and .571 on the exhaust. Then throwing a E-Force on it, what effect will the increased lift have on Boost?
Old Aug 27, 2010 | 11:43 AM
c6 batmobile's Avatar
c6 batmobile
Increased lift will just open the valve further and let more air in for your boost. Thats why guys with super charges and turbos often go with a forced induction cam to maximize their performance.
To Rocker Arm ?
