Caliper Paint - G2 or DupliColor
Old Aug 28, 2010 | 11:06 PM
LBear's Avatar
LBear
Default Caliper Paint - G2 or DupliColor
Which is the better of the two? They sell the red DupliColor at AutoZone for $20.
Which nets the better looks and long term durability?
Old Aug 29, 2010 | 03:41 AM
HOXXOH's Avatar
HOXXOH
From all the reports, it doesn't seem to make much difference what you paint them with as long as you clean and prepare the surface well.
Powdercoat looks good, but you have downtime and $.
A $5 DIY rattle can gives good results and you can touch-up easily.
Everything else is somewhere in between.
Old Aug 29, 2010 | 12:23 PM
dsp300c's Avatar
dsp300c
mike the powdercoater has good prices, core exchagnes possibly, very nice, quick shipping, etc. he has done a couple sets for me. give him a call or an email. he is a vendor on here.
http://www.thepowdercoater.com/
Old Aug 29, 2010 | 04:48 PM
LBear's Avatar
LBear
Do the brake calipers ever see temps over 500F?
That is what the DupliColor is rated to. I don't road race the car or anything like that.
Old Aug 29, 2010 | 04:49 PM
LBear's Avatar
LBear
That requires removing the calipers and bleeding the brake system, correct?
Also, when one gets the powder-coated caliper, that is someone else's caliper. In other words, that caliper could have 50k miles on it, while the one you turned in off of your car will only have 1k miles on it. The seals and piston could be going bad on that old caliper, right?
Old Aug 29, 2010 | 07:38 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
I don't think so unless its on the track for an extended time.
If you use enamel type of paint (Rustolium) and clean it real well to remove any dirt and oil, it should stick well. Wipe it down with a commercial paint prep or alcohol before you paint it because mineral spirits/paint thinner leaves behind some oil residue. A fine brush is fine because its a rough casting anyway and the bush marks will level out as it dries.
I would try this before spending the time and money to get them powder coated.
Old Aug 29, 2010 | 08:02 PM
bob guzzy's Avatar
bob guzzy
I never used anything on my unpainted calipers but the stuff from walmart, as long as the caliper is clean it will stick and stay.
Old Aug 29, 2010 | 11:26 PM
dsp300c's Avatar
dsp300c
yes you have to bleed it. mike rebuilds them. you should call and talk to him. really good guy.
To Caliper Paint - G2 or DupliColor
