Removing Navi Antenna
Old Aug 29, 2010 | 04:53 PM
studiovette's Avatar
studiovette
Default Removing Navi Antenna
I just took apart and removed my console to get my factory Navi out of my 07 C6. I have like 4 cables but not sure which is the GPS/Navi antenna. Does any 1 have any pics or can explain if I can even remove it?
Old Aug 29, 2010 | 06:33 PM
SavannahVette13's Avatar
SavannahVette13
it is located in the back left of the dash. it is held in by 2 rivets wich were a pain in the a** for me but def do-able. its silver square shaped
hope this helps
Old Aug 29, 2010 | 06:52 PM
studiovette
Thanks I found it. Did you take the dash pad off I don't c how you can do it any other way. Also did you just cut it off once removed? Thanks 4 ur help!
Old Aug 29, 2010 | 07:26 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
It is such a PITA to remove that you might just want to leave it in.
If you are going to sell your OEM Nav, the replacement antenna is not too expensive. How much is your time worth?
And if you are installing a new aftermarket Nav, you can just put it's antenna on top of the AC vents.
Hope this helps.
Old Sep 1, 2010 | 07:52 PM
SavannahVette13
no i didnt take dash off i took a long flat head screw driver and just pried the rivet open...it was a pain and took me a long time but i got it done..
To Removing Navi Antenna
