check engine light, help
Old Aug 30, 2010 | 09:45 PM
lyonsac4242's Avatar
lyonsac4242
Default check engine light, help
Hey guys,
The other day after a hard pull through 1st gear and then a little of 2nd, I got a check engine light. 2005 z51 mn6, runs fine, fuel mileage fine, took to autozone- code says check camshaft to crankshaft sensor or something like that. I brought it to dealer for active handling recall and to fix the check engine light. Well, they reprogrammed computer, which evidently solved nothing because the light came right back on. Any input? Thanks
Scott
Old Aug 31, 2010 | 02:21 AM
RamAir972003's Avatar
RamAir972003
Default Change the sEnsor
Okay they should have changed the sensor to the camshaft or crank if that does not solve problem the reluctor ring might be off just go back and tell them to put a new sensor on......
Old Aug 31, 2010 | 04:16 PM
SpinMonster's Avatar
SpinMonster
You may need a crank position sensor relearn.
Old Aug 31, 2010 | 07:41 PM
lyonsac4242
Default thanks
Thank you guys,
Works been busy, going to try and drop it off tomorrow. Hope they can handle it. I was wondering why they just reprogrammed the computer when it was reading a communication error.
To check engine light, help
