Water Leak
Old Aug 31, 2010 | 09:29 PM
questions's Avatar
questions
4th Gear
Default Water Leak
I discovered wet carpet on the passenger floor. The leak appears to be below the windshield at the corner by the door. The carpet and the seat have been removed. I am having trouble getting the kick panel off that runs along the door opening. Any suggestions on removal? The manual door release, I am having difficulty getting the carpet out from around it. Also any suggestions on where specifically anyone would suggest looking for the leak, maybe a body seam or penetration. Any assistance would be appreciated.
Old Aug 31, 2010 | 09:55 PM
c6 batmobile's Avatar
c6 batmobile
Maybe a window seal. Is your car still under warranty? If so I would take it in and let them deal with it.
Old Aug 31, 2010 | 10:01 PM
questions's Avatar
questions
4th Gear
No, 2007 Out of warranty five months
Old Aug 31, 2010 | 10:06 PM
c6 batmobile
Bummer. Check the window seals and the roof panel. Those are two of the worst culprits. Most of the kick panles just have those plastic push fasteners in them. There a pain to deal with.
Old Aug 31, 2010 | 10:26 PM
RicK T's Avatar
RicK T
Most of the front area leaks reported here have been traced to the windshield seal somewhere on the A-pillar.
Old Sep 1, 2010 | 10:12 AM
TXCyberSport's Avatar
TXCyberSport
Passenger floorbaoard on my 2010 GS was wet. Cause was the ac drain under the car was blocked by a wire harness and the water backed up in the passenger footwell.
Old Nov 7, 2010 | 08:40 PM
questions's Avatar
questions
4th Gear
Found the leak where a piece of fiberglass is glued using epoxy to the firewall in the corner behind the battery. The epoxy is on the inside and outside and was not completely sealing the fiberglass piece to the metal. The pc of Fiberglass has a harness going through the center but the epoxy was missing allowing a drip.
Old Apr 2, 2012 | 11:59 AM
05C6400's Avatar
05C6400
Does anyone have pictures of where the water drain tubes are located? I did a search and found pictures for C4 and C5, but none for the C6. My issue is that every time it rains I get water in the passenger side foot well. Thanks...
To Water Leak
