Halltech C6 Venom II
Old Sep 4, 2010 | 11:34 PM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
Default Halltech C6 Venom II
Halltech C6 Venom™ II is the direct bolt on replacement for the C6 Venom™ for the C6 Base Car with the LS2 motor. Bolt on 15 RWHP/12 lbs ft torque with our all new design. This intake is made from the same mold as the Killer Bee™ II that dynoed +15 HP/+14lbs-ft. on the Katech Engine Development Superflow dyno. The same huge high flow K&N Filter will flow over 1250 cfm, and feeds over 900 HP easily. This system uses the stock wiring, and MAF sensor for direct bolt on power that will not void your warranty. It comes with Halltech's Beehive™ Heat Shield to isolate the filter from engine heat and capture cold air with optional cutouts for cold air induction. Check out our C6 LS2 Conversion package for more power.
Online Store
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
423-915-6056
For service email:
orders@halltechsystems.com
www.halltechsystems.com
