Need help pulling Z06 engine
Old Sep 5, 2010 | 11:48 PM
74c395c4's Avatar
74c395c4
Default Need help pulling Z06 engine
Need to remove an 08 Z06 engine using an engine hoist. Where should I attach the chains on the engine? The back of the engine is under the cowl. I have the front of the engine off and the front of the car
Old Sep 6, 2010 | 12:23 PM
djbrun's Avatar
djbrun
I haven't done this yet, but do you have the intake off? Can you just fab a quick bracket to bolt to the back of the head and have it come forward where the intake would be? Just an idea.
DJ
Old Sep 6, 2010 | 12:36 PM
cencalc6's Avatar
cencalc6
Make sure the intake manifold is removed.Also drop the front cradle about an inch... so you can clear the Crank pulley.
Old Sep 6, 2010 | 01:35 PM
thesubfloor's Avatar
thesubfloor
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
It is possible to pull the motor without removing the intake but it's a LOT easier if you do.
You will however need a engine hoist leveler as I couldn't imagine trying to pull the motor without one. What I usually do is use 2 chains, one bolted to the front of the heads and the other to the back.
Old Sep 6, 2010 | 05:25 PM
4MuscleMachines's Avatar
4MuscleMachines
You can use this engine lift plate along with the leveler that thesubfloor recommended.
http://carshop.carshopinc.com/produc...011/C/S%202365
Old Sep 7, 2010 | 10:25 PM
74c395c4's Avatar
74c395c4
Thanks for the assistance. This is great.
Old Sep 8, 2010 | 12:11 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
You want the front of the engine to tilt up a bit to clear the front cradle and steering rack.
Lift it slow and make sure you got everything disconnected. It's a biotch trying to line up the Torque Tube (Spline) with the clutch when you are reinstalling the motor.
I normally drop out the drive train and then pull the engine out the top.
Old Sep 9, 2010 | 12:13 AM
69dodgecharger's Avatar
69dodgecharger
I usually attach to the valley pan bolts, works well and very easy to access once the intake is off.
To Need help pulling Z06 engine
