cleaning throttle body bore/relearning throttle position
Old Sep 6, 2010 | 01:42 AM
mbsigman's Avatar
mbsigman
Default cleaning throttle body bore/relearning throttle position
Howdy all. Car is 3 years old/13000 miles and I'd like to clean my throttle body/throttle plate. The service manual says that after the throttle body and throttle plate have been cleaned, the engine computer must relearn the throttle position.
The service manual describes the procedure to relearn the throttle position post cleaning. However, although I like to consider myself as having somewhat reasonable intellect, this procedure is awfully complex.
Can someone break the throttle position relearn procedure down for me in simple terms?
Thanks!
Mike
Old Sep 6, 2010 | 01:05 PM
mbsigman's Avatar
mbsigman
Anyone?
Old Sep 6, 2010 | 01:19 PM
jxhunte's Avatar
jxhunte
Unaware of any procedure required to relearn TB position post cleaning. I have had my TB off several times and never followed any special procedure following TB installation. I just reinstall and drive, never had a problem.
Old Sep 6, 2010 | 05:51 PM
RamAir972003's Avatar
RamAir972003
Default turn a/c on let it idle
turn a/c on let it idle for 15 min. to ten min.... just clean it with some cleaner.......
Old Sep 6, 2010 | 11:47 PM
vette6500's Avatar
vette6500
sounds like something i definitely need to do with over 108,000+ miles. if it's just a straight remove/clean/reinstall procedure:bb
To cleaning throttle body bore/relearning throttle position
