Brake fluid?
Old Sep 12, 2010 | 01:05 PM
coolhand5599's Avatar
coolhand5599
Default Brake fluid?
What is a good High Temp Brake fluid for road racing?
Old Sep 12, 2010 | 02:54 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Good = ATE Super Blue and ATE Type 200. Same brake fluid but they're different colors so you can see when the new fluid is coming through and the old fluid has been flushed. Motul RBF600 is good fluid as well.
Having said that the above are "Good", I don't recommend either for roadracing. They work, but I would get the best (IMHO), Castrol SRF. It isn't cheap, but you'll get longer life and far superior performance.
I'd post this question in the Autocrossing and Roadracing forum. You'll get better answers there from some very knowledgeable forum members.
San
Old Sep 12, 2010 | 02:55 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
The Search feature will get you a lot of info.
Ford DOT3 is pretty good if you change it recently.
GM makes a DOT 4.
Old Sep 12, 2010 | 02:58 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Now you know why I recommend the Autocrossing and Roadracing forum.
San
Old Sep 12, 2010 | 04:22 PM
timd38's Avatar
timd38
I use Wilwood Fluid.
Old Sep 13, 2010 | 12:27 PM
Chris_B's Avatar
Chris_B
AP600 is hard to beat for most racing applications. If you want the very best available, AP Racing PRF and Castrol SRF are used where brake run constantly at 2000°F. SRF has a slightly higher boiling point, but PRF has much better recovery properties.
Chris
Old Sep 13, 2010 | 03:59 PM
turbotuner20v's Avatar
turbotuner20v
On stock brakes the ATE SuperBlue will be fine. I run it on carbotech pads and blank c5 rotors and have good enough braking performance for track day events.
Old Sep 13, 2010 | 08:05 PM
Bill Dearborn's Avatar
Bill Dearborn
There are a bunch. Here are the ones I have used. Ford Super Duty DOT 3 although it isn't quite as good as it used to be. Its dry boiling point used to be 550 but is now spec'd at 500. It's the most cost effective fluid you can buy and its straight from the Ford dealer. Back a number of years ago Grass Roots Motorsports rated as the best kept secret in racing. Wilwood 570 (dry boiling point of 570) and costs about $6.00 per 12 oz container. Wilwood 600 Plus. I used this a couple of times but it is more expensive and the 570 wasn't boiling so went with the cheaper fluid. Actually never had any problems with the Ford fluid boiling either even though dropped to 500 degrees.
Bill
Old Sep 13, 2010 | 08:35 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
San
100%. I only use SRF and it is worth the extra money IMO.
Old Sep 14, 2010 | 09:33 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Old Oct 14, 2010 | 03:35 PM
stevette17's Avatar
stevette17
Bill
its still a good fluid even though its a dot4? don't the dot3 adsorb me moisture... I need something for street use just wanted to update a bit. iwas thinking the motul rbf660 or 600 since abit cheaper. Is the 660 better than the SRf?
Old Oct 14, 2010 | 03:44 PM
Like dem Vettes's Avatar
Like dem Vettes
BG Super DOT4
Old Oct 15, 2010 | 11:07 AM
bowtiguy's Avatar
bowtiguy
Originally Posted by carbotech adam
I ran Motul in my car for the first season. I'd bleed the brakes once a weekend, sometimes 2X on the fronts.
SRF bottle is much larger than a motul bottle ( almost 2X the size). So with that said SRF runs about 2X the $$$ as motul.
I ran 20 1/2hr track sessions this year on SRF and did not bleed them once. enough said!
Old Oct 15, 2010 | 12:11 PM
RichieRichZ06
St. Jude Donor '08
That was my reasoning as well. After taking into account the extra fluid cost required for multiple changes and time to do it, the SRF is a no brainer.
Old Oct 15, 2010 | 12:12 PM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
I'm still running a sale on SRF. 65 a bottle, can save a 5k front end hit at the end of the straight.
http://dougrippie.com/?p=430
Randy
Old Oct 15, 2010 | 03:53 PM
stevette17's Avatar
stevette17
so for street use get the motul 600 or just stick with the gm stuff?
Old Oct 15, 2010 | 05:01 PM
Chris_B's Avatar
Chris_B
Motul RBF600 is a bit overkill for street use, but it works great. Alternatively, you might consider their DOT5.1 product or AP Racing Formula 5.1. Both have outstanding properties and the correct viscosity for brake systems with advanced ABS and traction control (like the C6). They will also handle a bit of track duty, but not hard core racing or track abuse. And, each costs less than the RBF600.
Chris
To Brake fluid?
Old Oct 15, 2010 | 11:46 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Randy
Great price Randy.
San
Old Oct 15, 2010 | 11:52 PM
Gering's Avatar
Gering
Tolero Apto Victum
I have heard good things about Motul 600 RBF. I use it in my Vet, even though I do not track it.
Old Oct 29, 2010 | 12:07 AM
coolhand5599
How much do I need to buy for the entire system?
