Vibration during rolling stop
Old Sep 15, 2010 | 10:31 AM
m_LeDez's Avatar
m_LeDez
From: Houston, Tx.....'05 Corvette M6 LS3 Magnuson Heartbeat
Default Vibration during rolling stop
Looking for so advice.....
As I'm rolling to a stop, I'm feeling a vibration what seems to be coming from the front. It occurs ONLY while rolling to a stop only between 15-10 mph as I'm slowing down. The front tires show normal wear, not worn. The front brake rotors (Z06) are smooth and pads (Hawk Performance Ceramic) have ~75% pad left.
Is it possible one of my front hub bearings are going bad w/ ~46k miles?
Old Sep 16, 2010 | 08:45 AM
Bandit1's Avatar
Bandit1
Are you applying the brakes when you are experiencing the vibration?
Old Sep 16, 2010 | 10:04 AM
m_LeDez's Avatar
m_LeDez
Yes, while applying brakes rolling to a stop. The vibration (steering wheel & brake pedal) occurs only while slowing down as the speed drops between 15-10 mph and is consistant.
I might try having the rotors turned, but was wondeing if it's a front hub bearing going bad.
Old Sep 16, 2010 | 10:24 AM
Tikiman12's Avatar
Tikiman12
no that sounds like the rotors are warped. turn the rotors is your best bet
Old Sep 16, 2010 | 10:53 AM
Boomer111's Avatar
Boomer111
Have you had recent tire work done on the fronts, maybe overtightened lugs warped the rotors. This is my biggest fear when having the wheels taken off. I always ask and watch to see that they use an torque wrench properly.
Old Sep 26, 2010 | 11:07 AM
Bandit1's Avatar
Bandit1
Yep, I think you're experiencing rotor 'run out'. If they're not drilled & slotted, you can mic em to dertermine if they can be turned. If not, you're looking at replacement. Had the same thing happen on my 99 (drilled & slotted) and replaced them with GM Performance rotors.
Old Sep 26, 2010 | 12:19 PM
BEZ06's Avatar
BEZ06
Sounds to me like an uneven buildup of pad material - maybe pad imprinting. Read this StopTech White Paper about rotors:
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
Here's a cut-n-paste from the document:
if both disc and pad are not properly broken in, material transfer between the two materials can take place in a random fashion - resulting is uneven deposits and vibration under braking. Similarly, even if the brakes are properly broken, if, when they are very hot or following a single long stop from high speed, the brakes are kept applied after the vehicle comes to a complete stop it is possible to leave a telltale deposit behind that looks like the outline of a pad. This kind of deposit is called pad imprinting and looks like the pad was inked for printing like a stamp and then set on the disc face. It is possible to see the perfect outline of the pad on the disc. (FIGURE 5)
Fig 5
Keep reading and down toward the bottom you'll read about cleaning the rotors with garnet paper (NOT sand paper or emery cloth) to try to remove the uneven pad material buildup.
You can read everything about brakes on their site:
http://www.stoptech.com/tech_info/te...e_papers.shtml
Scroll down to "Removal of Uneven Pad Deposits From Rotors Using Aggressive Friction Compounds" to read about using your aggressive track pads to scour uneven pad buildup off the rotor to smooth it off.
Good luck with your problem, but as the StopTech documents say, these rotors just don't "warp", so I don't think that's your problem at all!!
Bob
To Vibration during rolling stop
