LS2 top to LS3
Old Sep 17, 2010 | 06:39 AM
timd38's Avatar
timd38
Default LS2 top to LS3
Here is the deal. LS3 heads are better than LS2, so I was thinking of getting a FAST 102 for an LS3 and LS3 heads (OE or Aftermarket, not sure which yet). I have two questions. Will all the LS2 parts bolt up and what cam would you use to go with it.
Old Sep 17, 2010 | 11:09 AM
m R g S r's Avatar
m R g S r
arent the bore diameters different between the two?
Old Sep 17, 2010 | 11:34 AM
timd38's Avatar
timd38
Yes, that is why LS7 heads won't work.
Old Sep 17, 2010 | 11:40 AM
dennis50nj's Avatar
dennis50nj
a lot of people did the LS3 and intake swap, and a cam its cheaper and you can sell your heads, but i havnt seen any good 1/4 mile results, even though the LS3 dynos higher numbers, it seems to produce slower 1/4 mile times once modded
Old Sep 17, 2010 | 03:51 PM
lockman's Avatar
lockman
yes you can and yes they produce more power I know spin monster did the swap on his LS2 but I don't know if he did any 1/4 mile times. but he liked the results.
Old Sep 17, 2010 | 06:48 PM
DaytonaFIC6's Avatar
DaytonaFIC6
This is a pretty popular mod in the GTO crowd and can definitely be done. It is known as the L92/L76 combo. It consists of the stock LS3 intake manifold and heads, but an LS3 FAST 102 should work also.
Old Sep 18, 2010 | 11:45 AM
timd38's Avatar
timd38
Thanks!
Old Sep 18, 2010 | 01:21 PM
seevi's Avatar
seevi
From what I understand, and I'm sure Spin will pop in here, LS3 heads breath better than LS2 heads, but, you will lose some compression if you don't deck the new heads.
Old Sep 18, 2010 | 03:44 PM
timd38's Avatar
timd38
I will give him a call.
Thanks!
Old Sep 19, 2010 | 12:22 AM
10mikeymike's Avatar
10mikeymike
Tim, I swapped out the LS2 heads for CNC'd L92/LS3 heads in order to install the LS3 version of the E-Force on my car. There is a compression loss, but that was desireable for the blower install. The L92's flow way better than the LS2's and they're reasonably priced.
Old Sep 19, 2010 | 06:45 AM
timd38's Avatar
timd38
Great! Bet your car us really quick!
Old Sep 19, 2010 | 07:20 AM
SpinMonster's Avatar
SpinMonster
Your timing couldnt be better my friend. Call me if you still have the number and I can sell you my existing LS3 top end. (Im going with the AFR 230 for high boost and the deck surface is better for that). Anyway, my set up consists of L92's(LS3) with a L76 ported intake manifold with stainless one piece valves and comp 921 springs. These parts were 1750 new and I will get the heads cleaned up and a clean-up mill and sell the parts to you for 1150 shipped. They have about 8k miles on them. I even have ARP head bolts if you want them too.
The heads with a .040" gasket will have 10.7:1 compression just like a stock LS3. I can have them milled further if you want it up near 11.1:1. Just let me know what cam you want to use so I know what the limit will be for milling/clearance.
I will help with your tune for free and also port your TB for free too unless I already did that.
Old Sep 19, 2010 | 08:05 AM
timd38's Avatar
timd38
I will call you in the morning. Going to mom's house after Mass for my birthday. Can you recommend a cam to go with it?
My goal is around 500HP. Is that realistic without going crazy?
Thanks!
Old Sep 19, 2010 | 09:57 AM
BornSUPERCHARGED's Avatar
BornSUPERCHARGED
PM sent
Old Oct 3, 2010 | 12:36 AM
presto_vette's Avatar
presto_vette
I will help with your tune for free and also port your TB for free too unles s I already did that.
in fact, i have an L92/Ls3 for my c5 .currently im running a TSP LS3 229/236 .624"/.615 will this make it to the 500hp point? im going to CNC the L92s ?
Old Oct 3, 2010 | 08:28 AM
SweetS10v8's Avatar
SweetS10v8
Ive got a set of Lingenfelter CNC LS3 heads in the classifieds, with the matching FAST 102mm. Id sell the the camshaft too if you want a matching setup (Comp LSR for LS3 heads 219/235 .607/.621 113LSA)
http://forums.corvetteforum.com/c6-p...mm-intake.html
Old Dec 1, 2010 | 04:54 PM
94 guy's Avatar
94 guy
timd38, check your pms. thanks
Old Jul 10, 2011 | 06:36 PM
tayimr0a's Avatar
tayimr0a
intresting
To LS2 top to LS3
