FAST install help needed
Old Sep 20, 2010 | 03:31 PM
Newton06's Avatar
Newton06
Default FAST install help needed
Went to begin the job & cannot figure out how to disconnect the fuel hose from the rail? I removed the clips that attach, but cannot pull the hose off; is there a procedure to remove the steel hose?
Off to a bad start.
Thanks.
Old Sep 20, 2010 | 03:35 PM
ls3gotcha's Avatar
ls3gotcha
Go to autozone and buy a fuel line disconnect tool. They come in a small pack of different sizes. for like 5 bucks. Push the tool over the line and push in towards the clip with the tool. With the other hand push the fuel line towards the rail and it will pop right off. Put some rags underneath cause some fuel in the lines will come out
Old Sep 20, 2010 | 03:36 PM
SDPC's Avatar
0SDPC
Former Vendor
You need a fuel line disconnect tool. Seen here at step 15 http://keliente.com/c5engine.htm
Old Sep 20, 2010 | 03:42 PM
Newton06's Avatar
Newton06
Thanks gents!
Old Sep 20, 2010 | 04:41 PM
Red06Vette's Avatar
Red06Vette
Newton06:
You don't need to remove the fuel line, ease the injectors out of the manifold and lay it on a cloth on the windshield. Be careful, if you pull an injector out of the fuel rail, you may get squirted with gas.
Old Sep 20, 2010 | 05:32 PM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
No need to remove the fuel line, it will spin around and lay on the windshield as Red06Vette mentioned.
have you read the "how to" online yet? I think you should as it will help you know how to handle any little obstacle.
Old Sep 20, 2010 | 09:27 PM
Newton06's Avatar
Newton06
Thanks folks, I purchased the kit at Auto Zone, which did the job. FAST installed successfully!
Old Sep 21, 2010 | 02:53 PM
Neumonic2002
Congrads! Now you need a tune!
Old Sep 21, 2010 | 03:37 PM
Newton06's Avatar
Newton06
Yeah, silly me just had it re-tuned a month or so ago; do you think another re-tune is in order? Seems to be running great.
I did notice the intake noise is considerably louder with the FAST versus the OEM piece.
Old Sep 21, 2010 | 05:50 PM
Neumonic2002
My tune was off, I think my tuner said I was pretty lean. He also had to re-tune the MAF as well.
John
Old Sep 21, 2010 | 06:03 PM
c6 batmobile's Avatar
c6 batmobile
Needs a tune.
Old Sep 21, 2010 | 06:36 PM
Newton06's Avatar
Newton06
OK, I will schedule a re-tune ASAP.
Thanks.
Old Sep 21, 2010 | 07:06 PM
timd38's Avatar
timd38
How long did the job take?
Old Sep 21, 2010 | 07:27 PM
Newton06's Avatar
Newton06
There was wine involved, more than a few mistakes, and a run to AutoZone. All told, ~5 hours including a test drive. I would say a mechanically competent person could easily do it in half that.
Old Sep 21, 2010 | 08:29 PM
timd38's Avatar
timd38
Thanks!
I keep plenty of wine.
To FAST install help needed
