I have a 05 , When you lift off the gas to shift the rpms don't seem to drop off.I have had several Vetts of the same vintage with the drive by wire and none did this. I have checked for any vacuum leaks and have found none.I have replaced the pedal assembly also. Cleaned the TB . It Idles perfect ,runs very nice just doesn't slow quickly down when you let off , it seems like you almost have to tap the brake to get a response. Anybody have any good advice on what to look for here. Thanks in advance for any help..
Thanks for the offer,I think Chuck Cow is closer to me at 3 hours away ,I will be tucking the car away for the winter in a month, So this may wait till spring .It probably wouldn't bother a normal person at all but I tend to be pretty **** about these things.I had never noticed anything like this in the previous vettes that Iv'e had so thats why it irritates me so much.
No problem.... Call me when you're ready....
While it IS likely in your tune, it's not a result of the mods unless somehow the reading the MAF gets has been messed with.
GM built "too much" airflow into the tables that control the way the rpms fall back to the base idle.
It helps protect the trans a bit and makes up for the fact that not everyone who buys a vette is a sharp driver.
If you'd like the idle to fall faster we can do that for you.
