LS3 PCV Disconnect?
Old Sep 20, 2010 | 06:59 PM
carpe dm's Avatar
carpe dm
Default LS3 PCV Disconnect?
How do you disconnect the PCV connection on a new LS3 without breaking it? Is there a tab or way to push it to get the dumb thing apart? It is probably simple, but I don't want to screw it up. Thanks.
Old Sep 21, 2010 | 12:00 AM
carpe dm's Avatar
carpe dm
ttt
Old Sep 21, 2010 | 02:07 AM
Mike's LS3's Avatar
Mike's LS3
Originally Posted by carpe dm
ttt
If you are talking about where the PVC clips into the plastic fitting that enters the air intake, then squeeze at the base of the PVC and it will release from the plastic fitting. To install, just push it back in and you will hear a click.
Old Sep 21, 2010 | 12:39 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
There is a clip near the base of the fitting. It covers about half of the circumference of the connector.
The clip slides in and out of the fitting. When engaged its sticks out a little. To release the clip, you push in or toward the center of the tube. Do not force it. If you push in at the middle, it should release fairly easily.
Old Sep 21, 2010 | 05:43 PM
carpe dm's Avatar
carpe dm
Thanks, guys.
To LS3 PCV Disconnect?
