P0803 1-4 upshift solenoid circuit error code
Old Sep 22, 2010 | 01:47 PM
bocallaghan's Avatar
bocallaghan
Default P0803 1-4 upshift solenoid circuit error code
So my 2006 has this error code. The engine light comes on every now and then so I got the code ran. What could cause this problem and what could I do to fix it.
Thanks,
Brandon
Old Sep 22, 2010 | 02:46 PM
RicK T's Avatar
RicK T
Likely the solenoid is bad. Here are a couple threads with info and suggestions to consider, and just be aware the eliminators can go bad and give the same code:
http://forums.corvetteforum.com/c6-s...kip-shift.html
http://forums.corvetteforum.com/c6-t...ode-p0803.html
