Will a Stall effect dyno readings?
Old Sep 26, 2010 | 03:33 PM
cell6ida's Avatar
cell6ida
Default Will a Stall effect dyno readings?
I know that if you swap out rear end gears....say to 4:10, that the dyno will read a little lower h.p. than is actually there.
Is the same true with a stall converter? Say a 3600?
Thanks!
Old Sep 26, 2010 | 04:10 PM
dennis50nj's Avatar
dennis50nj
Thanks!
it can effect tq readings
Old Sep 26, 2010 | 05:28 PM
HOXXOH's Avatar
HOXXOH
I doubt the HP readings will effectively be affected by a converter when the RPM exceeds that of the stall speed.
However, you can affect the HP numbers by doing the dyno pull in either 4th or 5th gear (A6 cars) and not properly compensating for the overall gear ratio effect the non-standard 1 to 1 high gear has on the results.
Old Sep 26, 2010 | 09:31 PM
cell6ida's Avatar
cell6ida
Will it show more, or less, tq than is actually there?
Old Sep 27, 2010 | 06:01 AM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
They generally show a lower reading, however, on the track, if the converter is sized correctly will show a gain.
Old Sep 27, 2010 | 09:26 PM
dennis50nj's Avatar
dennis50nj
well on mine it was the opposite, i cant find the dyno chart but mine was 488.1 cam only at 3000 rpm
Old Sep 30, 2010 | 08:19 PM
Ragtop 99's Avatar
Ragtop 99
Aftermarket stalls may be higher or lower efficiency than stock, so you may gain or lose HP at the rear wheels.
Definitely on the old dynojets, the torque ratings for big stalls were all messed up.
Old Sep 30, 2010 | 08:35 PM
mitchell c's Avatar
mitchell c
My car dynoed lower with my SS4000 than the ST3500 I had. However performance wise the bigger stall out performed the smaller stall.
Old Oct 1, 2010 | 12:06 AM
LS1LT1's Avatar
LS1LT1
In my opinion, yes it can but maybe not in every case. Many (most?) aftermarket torque converters are a little lighter (and in some cases, smaller) than stock so not unlike a lighter aluminum flywheel in a manual transmissioned car it could potentially read a little higher than say a stock converter, all else being equal. But contrary to that, for some crazy reason, I have often seen higher stalled automatics actually dyno lower after switching from the stock unit with no other changes.
Old Oct 1, 2010 | 02:11 AM
cell6ida's Avatar
cell6ida
Alright. So the answer is a definite Yes, No, Maybe So ! haha Thanks for the replies.
I'm about to put on ETP heads and the Yank 3600. The yank requires a 150 mile break in period, so I will be doing the heads and stall at different times. I'm just debating on which to do first.
1] The stall...then 150 mile break in...then heads and dyno tune
or
2] The heads and dyno tune for a "true" dyno reading...then the stall (which might skew the readings...but won't be redynoed..so I wont have to worry about the skewed readings)
Thanks again
Old Oct 1, 2010 | 05:37 AM
Agent White's Avatar
Agent White
St. Jude Donor '10-'12-'13-'14
1) heads
2) dynotune
3) stall
4) race
Old Oct 1, 2010 | 09:52 PM
AndyAmador's Avatar
AndyAmador
Originally Posted by Agent White
1) heads
2) dynotune
3) stall
4) race
I like the way he thinks....lol and Jeremy Formato dyno tuned my car and now I'm going to install a yankss3600. He said that it will show up lower on the dyno but at the track it will show the performance and the man knows his stuff.
Old Oct 2, 2010 | 12:39 AM
trauma's Avatar
trauma
Get your power band set and then pick an appropriate stall. JMO
Old Oct 2, 2010 | 12:54 AM
NavyVette89's Avatar
NavyVette89
Non lockup will mess the readings up. If you have an inertia only dyno than it's just the weight of the roller trying to flash the converter.
I've found that a loaded dyno (mustang or eddy current any other dyno) once you put in the vehicles weight it will flash the converter similar to the track and give you more accurate readings. Same with a turbo car with spooling the turbo. I had a car on my dyno that spooled to 28lbs with inertia only and when I inputed the weight of the car and used the eddy brake it spooled to 35lbs. Big difference in final numbers.
I used to hate dynoing stalled auto's at shows using inertia only. The crying and the bitching was non stop and was one of the reasons I sold the thing.
To Will a Stall effect dyno readings?
