Diablo Tuner question for 06 c6
I tried searching for some threads related to this but found nothing direct...
I have a predator tuner for my 2006 C6. I'm familiar how to hook it up correctly etc. When plugged in to the car and booted up i eventually get to an option of a 435HP 465HP and 500HP tune. My car has many mods including ram air w/ hood, corsia exhaust, 160 deg thermostat and I'm curious which is the correct tune to select? Additionally, I would like to know if these are preloaded tunes from the company of custom tunes that were added.
Maybe i can get some solid feedback on this? Id really appreciate some wisdom.
Thanks to all in advance!!
They seriously advertise that you can gain ~75HP with a handheld. Whoever is in charge of their marketing should get a raise if they have people believing that BS.
Here is my advise.... Take that handheld and either get a refund immediately or use it as a paperweight, since those ar ethe only 2 things it is good for. I would then take the money you paid for it and actually go to a reputable tuner that actually uses a dyno and a laptop to optimize your tune for your specific climate and conditions. The handhelds are a "cookie cutter" tune that will give you nowhere near the gains or safety built into an actual dyno tune.
With you already having a few mods done to the car, I would want to see some actual results, not just dump a mail order tune in it.
Contact the place/person you bought it from and find out the details.
I actually called SLP today. They are very helpful over the phone. They set they indeed were preset tunes specific to my upgrades done to the car. I can pretty much forget about the 500hp tune as the tune is specific to a car with cams, and headers. over the phone the rep told me i can safely run the 435hp and 465hp tune. depending on the quality of gas in my area i will see various results. he said try both and see what i like. the 435 might work better. I'm sure relative humidity plays a factor as well. I'm more concerned with longevity of the engine, so im gonna stick with the 435 tune. The thing is fast enough!!!
