wheels vs. tpms?
Old Oct 3, 2010 | 09:18 PM
C U IN REARVEIW's Avatar
C U IN REARVEIW
Default wheels vs. tpms?
i am looking to change my vette up with some aftermarket wheels. but doing so...does it eliminate the tpms (not all rims allow for them)? to clarify...there are alot of people running some sweet rims on this forum (360 forged,forgeline,ccw....ect)but do many/any of those wheels allow you to use the tpms?? or does it just need to become obselete if your not running oem wheels?
Old Oct 3, 2010 | 09:28 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
You can still use tpms with properly designed wheels. I have CCW and my tpms is flawless. I have read about issues with some other wheels.
San
Old Oct 3, 2010 | 09:58 PM
RicK T's Avatar
RicK T
For the wheels that don't mount the sensors in the stock way, there are 2 alternatives I'm aware of. One is "banding" where steel or plastic bands are used, like a big rubber band, to hold the sensors in the middle of the wheel. The second method is a "90 degree adapter" the mounts the sensor through whatever hole is provided in the wheel for a valve stem. Check this post AND the link at the bottom for the 90 degree adapters:
http://forums.corvetteforum.com/1561341919-post5.html
Old Oct 3, 2010 | 10:05 PM
C U IN REARVEIW
thanks
Old Oct 3, 2010 | 10:07 PM
C U IN REARVEIW
i am looking at ruff racing wheels (dont want to spend a ton on wheels but want to get a dif look on vette), are they any good? how heavy?
Old Oct 3, 2010 | 10:11 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Personally, I like forged wheels. When wheels break, bad things can happen.
San
Old Oct 3, 2010 | 10:13 PM
C U IN REARVEIW
San
.........but $$$$$$
Old Oct 3, 2010 | 10:33 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
.........but $$$$$$
You didn't buy a cheap car, why buy cheap wheels?
San
Old Oct 3, 2010 | 10:35 PM
C U IN REARVEIW
San
point taken
Old Oct 3, 2010 | 10:37 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
If you ever plan on aggressive driving or track use, I'd steer clear of cast wheels. If not, you might be fine with cast wheels. Just my $0.02.
San
Old Oct 3, 2010 | 11:30 PM
C6-LS2-MN6's Avatar
C6-LS2-MN6
....and the third, is to place them in a small/homemade/pressurized PVC tube after you air it up to 30psi or so and reprogram each sensor individually.
BTW-2010 and up models use different sensors
Old Oct 3, 2010 | 11:58 PM
C U IN REARVEIW
San
are factory corvette wheels forged?
Old Oct 4, 2010 | 12:13 AM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
No. But they are very nice cast wheels (Speedline from Italy). I prefer forged wheels.
Chances are you'll never have a problem with a quality cast wheel. If you do it will potentially be costly. I'd rather spend money on quality wheels that are lighter, stronger and more reliable.
San
Old Oct 4, 2010 | 12:44 AM
C U IN REARVEIW
San
thanks for your input
Old Oct 4, 2010 | 12:46 AM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Least I could do.
San
Old Oct 4, 2010 | 01:34 PM
CW4L's Avatar
CW4L
Supporting Vendor
No problems using TPMS with our 360 Forged wheels.
Old Oct 4, 2010 | 05:53 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Be sure the RUF wheels you are interested in actually fit the C6.
Offsets need to be correct and maybe consider caliper clearance for big brakes if that is also in your future.
Some downsides reported here about banding the sensors to the wheels is they sometimes come lose and because they are well inside of the wheel, pressure information is sometimes intermittent.
I'm also with the you-get-what-you-pay-for group. High quality forged wheels cost more because they are worth more.
At the very least, try to make your purchase using a trusted Forum Vendor, if you do have problems with an inexpensive wheel, you are much more likely to have it fixed/replaced/etc.
To wheels vs. tpms?
Old Oct 4, 2010 | 09:52 PM
C U IN REARVEIW
i absolutely agree with the (get what you pay for ) thought process...i just have a laundry list of mods i want to do and right now 5k for forged wheels will kill my budget...i just hate the stock look (wheels) on my vette and i don't want to just put a differant set of corvette wheels on it....it seems very commonly done (not a bad thing,just not for me)....i mean 5k would damn near pay to boost my ride...and that is way cooler than wheels....
Old Oct 4, 2010 | 11:16 PM
igo380's Avatar
igo380
That won't work after 20 minutes or so.
Old Oct 8, 2010 | 01:45 AM
C6-LS2-MN6's Avatar
C6-LS2-MN6
Why is that? Each one would need to be reprogramed to each of the 4 corners first though.
