2005 HVAC Control module codes?
Old Oct 3, 2010 | 09:51 PM
Ginny C6's Avatar
Ginny C6
CI 6-7-8-9-10-12 Veteran
St. Jude Donor '11
Default 2005 HVAC Control module codes?
Does the HVAC control module throw out codes? Or just the engine/ tranny?
Old Oct 3, 2010 | 10:03 PM
RicK T's Avatar
RicK T
Not that I know of.
Just FYI, if your HVAC head unit is acting weird in any way, it is just telling you it is dying. It's very common. If your car is under warranty hopefully it will act up while the dealer is looking at it. If not under warranty then I suggest you just order a new one before yours quits completely, possibly at a very unpleasant time and possibly causing you to wait a week or more for a new one.
Old Oct 3, 2010 | 10:20 PM
Ginny C6's Avatar
Ginny C6
St. Jude Donor '11
Yes, it's acting weird. I just don't want to spend $300 and find out it can be re-programmed or something.
Old Oct 11, 2010 | 07:12 PM
Ginny C6's Avatar
Ginny C6
St. Jude Donor '11
I finally got to my local GM dealer who after troubleshooting, tells me the Mode actuator valve is bad. The tech removed the HVAC control module, removed the glove box, jumped the unit out and watched the motor spin around, but the door won't move. The problem is, he says the dash has to come out to replace it, to the tune of $1500. I asked why the codes and the inability to control the A/C, and he stated the control unit cannot tell what the position is on the actuator, so it defaults to the mode it's in, and showed me about 5 codes it spit out. OUCH!
Old Oct 11, 2010 | 07:22 PM
RicK T's Avatar
RicK T
That's unfortunate but you aren't alone. We're seeing more '05's develop that actuator problem this year. Good luck.
Old Oct 11, 2010 | 07:24 PM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
glad you got it fixed, but to answer your original question, yes, the ac control has codes that can be accessed.
Old Oct 11, 2010 | 09:37 PM
Ginny C6's Avatar
Ginny C6
St. Jude Donor '11
Well, I haven't got it fixed yet. I'm checking around to see what my other repair options are.
Old Oct 11, 2010 | 10:12 PM
RicK T's Avatar
RicK T
Just a thought, not trying to spend your money but......if you do go ahead with this and the dash is removed consider that there are 4 (I believe) of those actuators in there. It might be prudent to replace all 4 while you're in there to save having to do it again next year when another 6 year old unit fails. Again, just sayin'.
Old Mar 12, 2011 | 01:53 PM
hwpratt's Avatar
hwpratt
1st Gear
Default HVAC Mode Actuator Valve
I just got the same bad news and a similar price quote on my 2005 C6 with only 12,500 miles on it.
Does anyone have any idea how many 'Vettes are experiencing this problem at such an early date?
Old Mar 12, 2011 | 02:14 PM
RicK T's Avatar
RicK T
No idea on numbers.....I doubt GM would make that known. It was/is a big issue with the C5's and appears to be carried over to C6.
A member posted a few months ago that the replacement part has a different color material so hoping it's better and will last. Here' that thead. Good luck:
http://forums.corvetteforum.com/c6-t...-material.html
Old Mar 12, 2011 | 05:04 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
It would sure be nice if anyone knows of a code reader that will read more than just the PCM?
To 2005 HVAC Control module codes?
