c6 harmonic problem
Old Oct 4, 2010 | 08:05 AM
BMW's Avatar
BMW
4th Gear
Default c6 harmonic problem
had a problem with 2007 corvette harmonic wobble
took it to local dealer they replaced it and now the shifter has a strong vibration if they did not mark the old one how can it be reset in the original position they did not install the weight in the new one that the old one had
Old Oct 4, 2010 | 01:48 PM
Rebel 1's Avatar
Rebel 1
Take it back. This is no good. A dealer has a warranty on their work/repairs.If the mechanic didn't mark the position i don't know what might have to be done. Maybe someone will chime in with more info. The weight also HAS to be installed. Don't let them b.s you, speak to the service manager and if that doesn't work talk to the DEALER OWNER. Good luck.
Old Oct 4, 2010 | 03:18 PM
Turbooo2u's Avatar
Turbooo2u
Is it a vibration at a particular RPM?
Old Oct 4, 2010 | 03:23 PM
BMW's Avatar
BMW
4th Gear
no
from idle on the higher the rpm the stronger the vibration
To c6 harmonic problem
