Intake manifold leak...
Old Oct 5, 2010 | 01:46 AM
dfinke23's Avatar
dfinke23
Default Intake manifold leak...
I read online today that one of the symptoms of an intake manifold leak is wet (oil/fuel?) spark plug threads. How would a vacuum leak cause this?
Old Oct 5, 2010 | 02:01 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
I posted in your other thread also. I would assume you would see the plugs wet because the air introduced to the motor after the MAF would cause the O2's to see a lean condition and the PCM would add a ton of fuel to correct it.
