Fast 102 LS2 intake Q
Old Oct 5, 2010 | 02:45 PM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
Default Fast 102 LS2 intake Q
Has anyone hooked up to the vacuum port on the back of the intake for there NPP mufflers? If so, was the port open or did you have to drill it out?
John
Old Oct 6, 2010 | 10:12 AM
Neumonic2002
reason I ask: I remember hearing about a member that tried to hook up his NPP to the back of the manifold and it was not open, just don't want to have to remove the intake to drill it out.
Old Oct 6, 2010 | 11:13 AM
Jim_H's Avatar
Jim_H
You've got to drill it out, I even called Fast to confirm, I wish I knew this prior to installing it. Having mine done now while its in the shop for a few other things.
Old Oct 6, 2010 | 03:49 PM
Neumonic2002
That is what I was afraid of.
Going to make my NPP install a bit more interesting.
It was probably in the instructions, I had stock mufflers at the time I installed mine unfortunately.
Thanks,
John
Old Oct 6, 2010 | 09:55 PM
Streetk14's Avatar
Streetk14
Is this for an LS2 or LS3? My LS3 102 had a little molded plastic nipple covering the NPP vacuum port on the back of the manifold. I had Corsa mufflers when I installed it, so I left it alone. When I went to my B&B Fusions, I had to just twist/break the nipple cover off and the vacuum port was open. No need to drill, at least on the LS3 version.
Old Oct 6, 2010 | 10:05 PM
Neumonic2002
glad that was the case for you, mine is for an LS2 and it isn't looking good.
I will pop the cap off of it and fire up the car to see if there is any vacuum otherwise......plan b i guess
Old Oct 6, 2010 | 10:33 PM
Jim_H's Avatar
Jim_H
Maybe mine was broken off, I'm having a few minor issues with my tune and maybe it's cause by what could be a small vacuum leak, but I figure it would be running much worse than this. I did call Comp and the guy that answered told me it had to be drilled out, I hope he was wrong, let me know what you find.
Old Oct 6, 2010 | 11:01 PM
Streetk14's Avatar
Streetk14
Maybe I'm confused here. The plastic cover on the vacuum port might have been on the stock LS3 manifold. Now that I really think about it, I think it was the LS3 manifold
Now it's all coming back to me. I needed a vacuum plug to cover the NPP port on the FAST when I installed it. I remember thinking I was lucky I was at my shop and had some extra plugs laying around. I don't think the instructions mentioned it.
I am also 100% sure that I did not have to drill out the NPP port on the back. I believe it was just open and would have resulted in a vacuum leak if I had not plugged it. Again, this was on the LS3 FAST intake.
Old Oct 7, 2010 | 12:20 PM
Neumonic2002
I appreciate the feedback!
Either way I will take my plug off and fire up the car to see if I hear or feel a vacuum leak as my first step.
Thanks guys
John
Old Oct 7, 2010 | 01:16 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Just tap into the emissions vacuum line on the left side behind the throttle body. It's a lot easier to get to!
Old Oct 7, 2010 | 02:37 PM
Neumonic2002
Ben mentioned something about that, I will use that as a back-up if my vacuum port isn't already open.
Thanks for the drag radial tip in the other thread as well Joe.
To Fast 102 LS2 intake Q
