oem wheels vs. forged.......weght vs. functionality
Old Oct 6, 2010 | 02:02 PM
C U IN REARVEIW's Avatar
C U IN REARVEIW
Default oem wheels vs. forged.......weght vs. functionality
i am looking to buy some wheels to change the look of my vette...would love to get some forged....but what i am wondering is....is the benefits of a forged rim really that much better/more noticable??? as far as weight,cornering (rigidity),stability,ect.....or are they more just for show. im sure they are better than oem...but how much better...$5k ????
Old Oct 6, 2010 | 02:17 PM
NYC6's Avatar
NYC6
I'll let others debate the main issue here but I will offer, CCW forged wheels can be had new for a good amount under $5K.
Old Oct 6, 2010 | 04:05 PM
haljensen's Avatar
haljensen
Forged just means the way the wheel was manufactured, not its weight. All aluminum wheels begin life as a casting.
There are forged wheels heavier than stock cast wheels, it depends on the style of the wheel. If more metal is used in the design it will weigh more.
Old Oct 6, 2010 | 04:08 PM
C U IN REARVEIW
so is forged alot stronger? if im not road racing or dragging the car....do i need to worry about what wheels are stronger than others?
Old Oct 6, 2010 | 04:31 PM
haljensen's Avatar
haljensen
I haven't heard of any stock cast wheels failing even under racing conditions. If you hit something any wheel can fail.
Old Oct 6, 2010 | 04:36 PM
C U IN REARVEIW
one more question...how much power saving is it per lb of reduced wheel weight (obviously the lighter the wheel the easier it is to turn)...thanks for your input.....
Old Oct 6, 2010 | 05:24 PM
trauma's Avatar
trauma
The only way to figure that out would be a before and after dyno and the gains would be so small (assuming we're not talking about a 10lb+ difference per wheel) it could be construed as dyno variances. Also it will depend on where the extra weight is carried in the wheel. The closer the weight is to the center of the wheel the less effect it will have on power.
Old Oct 6, 2010 | 05:45 PM
C U IN REARVEIW
thats what i was assuming....thanks
To oem wheels vs. forged.......weght vs. functionality
