C6 HUD install.....!???, any good pointers??? Thanks
Old Oct 9, 2010 | 08:50 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Default C6 HUD install.....!???, any good pointers??? Thanks
I am installing the HUD on Sunday into a 2008
Some good how to's here on the cf
anything to watch out for??
Old Oct 9, 2010 | 08:56 AM
op z's Avatar
op z
If you use the red crimp connectors, make sure they are properly installed before you button it up. Otherwise you will be opening it up agan.
The cut the duct method is the easiest way to get this done. I did mine over a year ago and you would never know the difference.
Old Oct 10, 2010 | 04:11 AM
SteveDoten's Avatar
SteveDoten
Is the cut/duct in the FAQ?
Old Oct 10, 2010 | 09:13 AM
op z's Avatar
op z
No, but it is discussed in several posts.
Old Oct 10, 2010 | 09:17 AM
op z's Avatar
op z
Remove the instrument panel (~15 minutes) cut the upper HVAC duct with a hacksaw blade (~30 minutes), installed the projector(~30 minutes), taped the hvac duct back in place, wire the components and reinstall the instrument panel. The cut the duct method gets the installation time down to about 2-1/2 hours. The hvac duct is shown on page 33 of the instructions. The steering wheel does not have to be removed. There is plenty of room if you are careful. If you have common hand tools you can do this mod. Study the instructions. THe more you study the instructions the more confident you will be.
Old Oct 11, 2010 | 07:40 AM
SteveDoten's Avatar
SteveDoten
It's done
pulled dash
cut duct seems smarter
this info needs to be more common
No worries on an air duct
wiring was simple, x6 solder connections
Old Oct 11, 2010 | 07:55 AM
SpinMonster's Avatar
SpinMonster
A simple search with the words HUD INSTALL yields lots of info including this DIY thread with easy steps and lots of Pics.
http://forums.corvetteforum.com/c6-t...e-install.html
I post it for others looking for the info.
The search feature is your friend.
To C6 HUD install.....!???, any good pointers??? Thanks
