Just got a 05 vette with 25k miles on it. A couple days the cluth out of no where hits the floor and wont spring back up. it will only come up if i reach down and pull it up. When the clutch is on the floor it doenst disengage. I cant shift it into gear. I did some searching and did the protocol that i found on here (http://forums.corvetteforum.com/c6-z...-and-cure.html)
After that didnt work the clutch was bleed and still no pressure. Anything else guys?
Well, could be a bad master cylinder or slave cylinder or clutch pressure plate (spring). You need to do some diagnosing with help from the more knowledgeable folks here. Here's a recent thread that will get you started thinking but give it a day or two for replies here. Good luck and please let us know what happens.
