Suspension upgrade?
Oct 9, 2010 | 09:57 PM
St. Jude Donor '11
Suspension upgrade?
Have an 06 Z51, suspension is stock. What upgrades are available without going nuts $$ wise (poly this,Bilstein that,etc)....
Mailny street use.
Oct 9, 2010 | 10:36 PM
Quote:
Originally Posted by
revo1059
Mailny street use.
Bilstein Sports because they're dirt cheap and your OE Sachs dampers wore out two years ago.
Michelin Sport PS/2 ZPs, the next time you need tires. 30psi front, 29psi rear.
Alignment.
Oct 10, 2010 | 02:21 AM
My '05 A4 is (was) base suspension. I upgraded and the car is unbelievable now. What made the difference for me was the combination of:
Pfadt adjustable coilovers w/ poly bushings
Z51 sway bars w/ poly bushings
removing GM leaf springs
upgrade dampers
road tested wheel alignment
4 point balance
lowering ride height
steering adjustment
performance wheels/tires
(see
profile )
Major improvement in handling.
Oct 10, 2010 | 10:39 AM
St. Jude Donor '11
I was trying to avoid coilovers due to the $ (I want to save those pennies for go fast stuff)
Oct 10, 2010 | 12:41 PM
revo1059
Read up on the coilover vs leaf spring post in the tech forum. Unless you are a hardcore racer, stick with getting Bilsteins or the Konis. I'm actually looking to change mine out also. I'll probably end up going with the Bilsteins based on all the rave reviews. Plus, they are much cheaper than the Konis.
Oct 10, 2010 | 12:45 PM
I did the Pfadt kit without the control arm bushings and am very happy. Did Bilsteins, but am very happy with my second upgrade.
Oct 10, 2010 | 08:17 PM
revo1059
Mailny street use.
Z51 is upgraded suspension. What are you trying to accomplish?
