Old Feb 20, 2015, 05:59 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
c6 coolant flush
Old Oct 13, 2010 | 07:23 PM
mercury51's Avatar
mercury51
Default c6 coolant flush
any info will be greatly appreciated
bill
Old Oct 14, 2010 | 02:14 AM
Rebel 1's Avatar
Rebel 1
Get the front in the air loosen the drain plug on the lower right of the radiator, flush everything good and replace Dexcool, SLOWLY. I did this about 5 months ago. Piece of cake. The system practically bled itself of air unlike having to "burp" the C5's. If you want to check for air, there is a hose in front coming off the drivers side head near the top you can disconnect to see if there is fluid coming out of it. Good luck.
Old Oct 14, 2010 | 10:57 AM
Boomer111's Avatar
Boomer111
There is specific procedure to follow per GM. Having to do with running at a certain rpm and having heater turned up etc. It is not just a drain and fill scenario.
Old Oct 14, 2010 | 03:33 PM
stevette17's Avatar
stevette17
how much fluid comes out from just doing a drain?
Old Oct 14, 2010 | 11:04 PM
Rebel 1's Avatar
Rebel 1
I did mine Exactly as i stated. Couldn't have been easier. As for the heater i involved it but i have not heard of these cars with "heater control valves" like the older cars. I only had to cycle the rpm's a few times. The system bled itself.
With just a drain i got out 2 gallons.
Old Oct 15, 2010 | 10:41 AM
Boomer111's Avatar
Boomer111
That what I drained out too 2 gallons. Well not me personally but I watched!!
Old Oct 15, 2010 | 10:55 AM
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
i was looking to flush the system and use something other than dexcool as i here it corrodes aluminum, also to keep engine temps down i wanted to run a more agressive mix in terms of %water, what is the minimal amount of antifreeze needed provided i live in the midwest, and will be running water wetter
Old Oct 15, 2010 | 04:04 PM
Boomer111's Avatar
Boomer111
Better do more research on this. If you do change anti freeze type be sure to get all the Dexcool out, with very persistent flushing.
With water wetter you can run straight water only, with the addition of the wetter, if you desire.
Old Oct 15, 2010 | 07:37 PM
SinisterC6's Avatar
SinisterC6
Speedy
so i assume water wetter has antifreeze properties, thanks,
they make an additive that breaks down dexcool, you flush the system, add the killer, flush again then free to do what you want
Old Oct 16, 2010 | 02:22 AM
Rebel 1's Avatar
Rebel 1
Old Oct 16, 2010 | 12:09 PM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
No antifreeze properties, but it's compatible with DexCool and others.
Old Oct 16, 2010 | 01:58 PM
SinisterC6's Avatar
SinisterC6
Speedy
well i know pure water wetter and distilled water provide the most cooling, my concearn is that the coolant will freeze come -30 deg days
Old Oct 16, 2010 | 05:00 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
GM has been using Dexcool in the Corvette for over a decade, and there have been very few problems that might be related to that use.
Experimenting can be fun, or frustrating and expensive.
Old Apr 25, 2011 | 10:14 PM
rwilkin1's Avatar
rwilkin1
Cruising
I find it funny that people will spend 50K to 100K on a car that has had as much testing as the Corvette then replace the coolant with a fluid that will void their warranty. I can see performance upgrades and exterior improvements but the fluids in your car have been tested and in some cases designed for your car or engine. I heard Extra Virgin Olive Oil makes your engine run cleaner and you can gain 45 HP in the process send me $5 and I will give you the ratio's. ))))))
Old Apr 26, 2011 | 11:18 AM
Ragtop 99's Avatar
Ragtop 99
if your car is exposed to -30* temps, you need to stay at 50/50.
There should be a mixture chart on the bottle, showing the mix% and effective temp. I confirm mix ratio with an antifreeze tester after a couple days use.
Old Apr 26, 2011 | 01:09 PM
Gearhead Jim
St. Jude Donor '13
Me thinks I saw a chart somewhere showing that a 50-50 mix also has a higher boiling point than 100% water.
Can anyone post a chart or a link?
Old Apr 26, 2011 | 04:07 PM
Ragtop 99's Avatar
Ragtop 99
The antifreeze mix definitely has a higher boiling point. Even adding 20% - 30% coolant significantly increases the boiling point. Something has to fail to get a 20% coolant mix to boil over in normal driving. Only time I've ever seen over 230* with a 160 t-stat is with a stuck thermostat or when I miswired my fans on my 99. :o
Maybe the road race guys see high coolant temps when the oil hits 270+
I've also seen some undersized systems (i.e. mods added far in excess of stock capacity) hit 240*
To c6 coolant flush
Old Apr 26, 2011 | 04:53 PM
LEAVINU's Avatar
LEAVINU
.... it's a sad day if you really believe this.
We're talking 15deg more tops with a 50/50 mix actually.
Old Apr 26, 2011 | 05:20 PM
TLK's Avatar
TLK
St. Jude Donor '09-'11
GM DexCool is not a great product. See the following links about DexCool
http://www.sancarlosradiator.com/dex-cool.htm
http://www.sancarlosradiator.com/dex-cool_pics.htm
If want to keep using a "DexCool" like product, so as to not void your warranty, use a somewhat better product. With any coolant, you should be replacing it every two years. With the original GM factory fill DexCool, I was sorry I didn't do it the first year as there was a little bit or orange stuff stuck inside the overflow tank.
I use Zerex DexCool.
http://www.valvoline.com/products/br.../antifreeze/41
Old Apr 26, 2011 | 07:33 PM
LEAVINU's Avatar
LEAVINU
Uh oh....... you've done it now.
