Loud POP when I press the start button!
Old Oct 18, 2010 | 06:07 PM
scottss's Avatar
scottss
Default Loud POP when I press the start button!
Well, I just did a fuel upgrade for my E-Force. I did some 65lb injectors as well as upgraded the fuel delivery to both sides to each of the fuel rails (Motorhead's mod). Saturday, this morning, and at lunch today...when I press the start button, a loud, metallic POP occurs and the car tries to turn over but doesn't...press the button again and it starts...what the heck is this!? My tuner/installer said to bring it by tomorrow morning so he can have a look...he said that one of the new injectors could have some fuel seeping into something and that sound is from that fuel igniting or something...I have no idea what he meant....what could this sound be? And should I be concerned to drive home?
Scott
Old Oct 18, 2010 | 08:02 PM
Tikiman12's Avatar
Tikiman12
the drippy injector sounds logical to me. while the car sits a small puddle of fuel is building in one cylinder, then a spark ignites it and POP but does not turn the motor over.
The sooner you get it back to your tuner the better
Old Oct 18, 2010 | 08:41 PM
Motorhead-47's Avatar
Motorhead-47
No clue on this one...share when you know what it is/was.
Old Oct 18, 2010 | 11:14 PM
Spying Beast's Avatar
Spying Beast
Sounds like something is shorting out to me...
Take it to a tuner QUICK!
Old Oct 19, 2010 | 07:51 AM
Telepierre's Avatar
Telepierre
I get a "half a pop" as well at re-start after a gas refuel or short stop. No pops at first start in the morning.
Old Oct 19, 2010 | 08:02 AM
Motorhead-47
If you suspect a leaky injector I'd get a fuel pressure gauge on the car. When you shut down the car the gauge will initially drop a few psi as the pump shuts off but should then hold steady. If you have an injector leak the fuel pressure will bleed off pretty quickly.
Old Oct 19, 2010 | 04:23 PM
scottss's Avatar
scottss
bump...
Tuner could not duplicate the issue (always happens that way)...he is re-flashing the tune to see if that helps...if it happens again, he said to bring it back to him....grrr
Scott
To Loud POP when I press the start button!
