QUICK! How do I remove the steering column cover?
Old Oct 20, 2010 | 04:41 PM
masksqueeze's Avatar
masksqueeze
Default QUICK! How do I remove the steering column cover?
I'm trying to isolate a noise coming from my steering wheel/column area, I've got the airbag cover removed, but I can't figure out how to remove the damn shroud that goes around the steering column (the black bezel the turn signal and wiper controls come through). I put a long screw driver into both holes and I still can't figure this out.
Old Oct 20, 2010 | 05:05 PM
cencalc6's Avatar
cencalc6
there is 2-3 screws underneath the cover, after you unsrew seperate both bottom and top cover.
Old Oct 20, 2010 | 05:25 PM
masksqueeze
I must not have a long enough screw driver than. I haven't hit any screws in the holes.
Old Oct 20, 2010 | 07:07 PM
moog5050's Avatar
moog5050
There are two small holes in the bottom cover that you use to unlock the airbag clips. These do not have screws in them. I suspect cencal is referring to other screw locations. The airbag clip holes are small.
Old Oct 20, 2010 | 07:14 PM
charlietuna's Avatar
charlietuna
Default column cover
consult your chevy dealer. There are no screws in the cover and I think the tilt lever pulls out. The covers snap together. I havent worked on a C6 I use to work at Saginaw Steering where we built colums. Don't screw up, it will cost you.
Good luck
Old Oct 20, 2010 | 08:27 PM
cencalc6's Avatar
cencalc6
You guys are correct, there is No screws underneath the cover... I had to double check Here's a write up I did when I swapped out my steering wheel. There is a 1" rubber strap the hold both pieces together... firmly pull towards the front of car and it should come out.
http://forums.corvetteforum.com/c6-c...ck-spring.html
Old Oct 20, 2010 | 10:31 PM
masksqueeze
Do I have to remove the steering wheel to get it out?
Old Oct 21, 2010 | 07:14 PM
masksqueeze
Bump
Old Mar 20, 2021 | 02:38 PM
bp308's Avatar
bp308
Can you tell me how to remove the cover on a C4 (91)
Old Mar 20, 2021 | 09:11 PM
Sox-Fan's Avatar
Sox-Fan
Might be more appropriate to ask in the c4 forum than in the c6 forum. People there are more familiar with the platform.
To QUICK! How do I remove the steering column cover?
